TbirdMan Posted March 27, 2012 Share Posted March 27, 2012 OK, this morning my car has started to make a squeaking noise from my left front wheel. I have looked and there is nothing rubbing, is this a wheel bearing? That is the only thing I can think it could be. Any other ideas? It is a rhythmic squeak at low speeds and a squeal at high speed. Link to comment Share on other sites More sharing options...
98LGTLover Posted March 27, 2012 Share Posted March 27, 2012 Could be a wheel bearing. When you have a bad wheel bearing it roars as you go down the road. I just had my left front one done a couple weeks ago. Link to comment Share on other sites More sharing options...
TbirdMan Posted March 27, 2012 Author Share Posted March 27, 2012 See, that's just it, it doesn't make any noise going stright, only in turns. I put it up on a jack and I could feel no movement in the bearing. My only other thought was maybe the brakes, but they look OK except for the grooves where the "crossdrilled" holes are, and those have been there since I bought the car. I recorded the noise and will try to upload it. Link to comment Share on other sites More sharing options...
Reckoner Posted March 27, 2012 Share Posted March 27, 2012 It could be ur half shaft bearings getting wore out that would make the sound going around corners Link to comment Share on other sites More sharing options...
TbirdMan Posted March 27, 2012 Author Share Posted March 27, 2012 This axle was replaced not long ago, or do you mean the diff output bearings? Link to comment Share on other sites More sharing options...
Reckoner Posted March 27, 2012 Share Posted March 27, 2012 This axle was replaced not long ago, or do you mean the diff output bearings? No i dont mean the diff bearing and it could be the wheel bearing if ur driving it you might not hear it until its a bit to late Link to comment Share on other sites More sharing options...
TbirdMan Posted March 27, 2012 Author Share Posted March 27, 2012 Well based on the lack of slop in the wheel and the fact that the wheel can't actually fall off from a bearing going out, I think I can drive it for a bit longer at least till the weekend. Link to comment Share on other sites More sharing options...
98LGTLover Posted March 27, 2012 Share Posted March 27, 2012 When my wheel bearing was first going out it just did high pitched squeaking noises. I could here it more when I was going through a bunch of parked cars and the noise would bounce off the cars. As it got worse the squeaking sort of went away and the roaring noises really set in. Link to comment Share on other sites More sharing options...
Taylorbailey2 Posted March 28, 2012 Share Posted March 28, 2012 Blown strut?? making the wheel scrap on the tire?? Link to comment Share on other sites More sharing options...
Taylorbailey2 Posted March 28, 2012 Share Posted March 28, 2012 Fender scrap on the tire* Link to comment Share on other sites More sharing options...
silverone Posted March 28, 2012 Share Posted March 28, 2012 have you checked your brakes Link to comment Share on other sites More sharing options...
TbirdMan Posted March 28, 2012 Author Share Posted March 28, 2012 The sound doesn't change under braking, and it isn't fender rub. Link to comment Share on other sites More sharing options...
TbirdMan Posted March 30, 2012 Author Share Posted March 30, 2012 hmm, sound randomly went away, so either it got better...or worse. Link to comment Share on other sites More sharing options...
