bmx045 Posted June 19, 2012 Share Posted June 19, 2012 Did subaru change the LCA in 05-09? (non spec-b) I looked on opposed forces and am finding conflicting information between them and fredbeans and trademotion. Reason being, I'm able to acquire 05 LGT LCA's with avo bushings for a decent price, not sure if fitment is askew for my 08 model year. Your help in this matter would be quite appreciated. Thank you for your time, and have a good day. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 19, 2012 Share Posted June 19, 2012 Call Fred Beans and ask them. I would say they are the same part. May Be subaru figured out to put better bushings in the later years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ericem Posted June 19, 2012 Share Posted June 19, 2012 It is the same part what changed is the cutouts in the control arms in later years. I guess for water to escape better and possibly slightly stronger either way 05-09 bolts in... Link to comment Share on other sites More sharing options...
bmx045 Posted June 19, 2012 Author Share Posted June 19, 2012 I do see that the triangle plate has changed, not sure about the lca itself, or if there will be a conflict in fitment. Link to comment Share on other sites More sharing options...
ericem Posted June 19, 2012 Share Posted June 19, 2012 Bushing might have been better I installed two new complete control arms and comparing my old to new they changed the cutouts like i said bushing looked similar could still be better. Link to comment Share on other sites More sharing options...
bmx045 Posted June 19, 2012 Author Share Posted June 19, 2012 i do believe subaru altered the oem bushing at some point, but that's a moot point. aftermarket bushings are 05-09 anyway for fitment. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 19, 2012 Share Posted June 19, 2012 i do believe subaru altered the oem bushing at some point, but that's a moot point. aftermarket bushings are 05-09 anyway for fitment. Yea, why improve a marginal design that works for a while. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
