Busuto05 Posted January 2, 2011 Share Posted January 2, 2011 05 Lgt w/87K. Location ME, brrrr! Time for a oil change. Car has Mobil 1 syn since orig owner has ran this for a while. Oil changes come fast for me (400 miles a week/ all highway @ 70/75 mph). I intend to do 3K intervals because of miles on car. My question(s): Keep using synthetic? Is it ok to switch back to reg oil? Thanks Link to comment Share on other sites More sharing options...
joeleodee Posted January 2, 2011 Share Posted January 2, 2011 IBRao. Link to comment Share on other sites More sharing options...
birmy Posted January 2, 2011 Share Posted January 2, 2011 As I understand it you do not want to switch back to conventional oil Link to comment Share on other sites More sharing options...
brilliant sleeper Posted January 2, 2011 Share Posted January 2, 2011 Synthetic with our cars always! Turbo's need the good stuff Link to comment Share on other sites More sharing options...
Busuto05 Posted January 2, 2011 Author Share Posted January 2, 2011 As I understand it you do not want to switch back to conventional oil I'm not the original owner if thats what you mean. Got this car with 84K, orig owner has run Mobil 1 synth. I ran synth oil for longer oil change intervals on na cars till miles got up there then swithed to reg oil and went back to 3K intervals. Been doing this commute for 11 yrs so cost is a consideration as well though NOT the deciding factor:) Just wondering if I switched back to reg oil, would I have any complications? Link to comment Share on other sites More sharing options...
Busuto05 Posted January 2, 2011 Author Share Posted January 2, 2011 IBRao. ? Link to comment Share on other sites More sharing options...
applesauce Posted January 2, 2011 Share Posted January 2, 2011 Even with a NA car and especially with a turbo car if its run synthetic all its life keep running synthetic. If the original owner has ran Mobil 1 XXWXX keep running that oil and avoid the Mobil 1 high mileage "special oil" just keep running the regular oil in the recomended weight Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 2, 2011 Share Posted January 2, 2011 ? Stick around for a while and you'll find out what that means. You'll most likely be fine switching back to regular. Personally, I'd stick to synthetic. I'm using Pennzoil Platinum. Link to comment Share on other sites More sharing options...
fixem2r Posted January 2, 2011 Share Posted January 2, 2011 With that type of mileage, I would stay with the Synthetic. I would tell you the same if you where running dyno oil for that long. Most oil companies will say it is ok to switch, but engine builders will disagree and say to stick with what was used for the life of the cars mileage. Regarding your miles and oil change interval. Changing every 3k is actually wasting money. You can definitly go longer and if you what a sense of security have an oil analysis done at 5k miles. Bet it comes back clean. Now longer intervals due depend on the nature of your oiling system and if you are still running the banjo screen. Personally I use AMSOIL SSO in my Legacy and XL in the minivan. Link to comment Share on other sites More sharing options...
Luchin Posted January 2, 2011 Share Posted January 2, 2011 Can the banjo filter be permanantly removed?!?! Link to comment Share on other sites More sharing options...
apexi Posted January 2, 2011 Share Posted January 2, 2011 I would switch back to conventional oil if you insist on sticking to a 3k oil change interval, especially since they're highway miles which are very easy on oil. Link to comment Share on other sites More sharing options...
gil_ong Posted January 2, 2011 Share Posted January 2, 2011 also, you don't HAVE to do an oil change every 3k miles. order a kit from these guys and get your oil tested. http://www.blackstone-labs.com the test results will actually tell you what state your oil is in and if you can push the interval out. Link to comment Share on other sites More sharing options...
-The Boss- Posted January 2, 2011 Share Posted January 2, 2011 Why this forum? Is it specific to the 05-09's Why cant people post in the correct forum anymore? I use Walmart oil 0w-50 Link to comment Share on other sites More sharing options...
fixem2r Posted January 3, 2011 Share Posted January 3, 2011 Why this forum? Is it specific to the 05-09's Why cant people post in the correct forum anymore? I use Walmart oil 0w-50 Really, why give the OP a hard time for this, if it is in the wrong forum then the mods will take care of it. No comment on the Walmart oil or the weight/viscosity you are using. Link to comment Share on other sites More sharing options...
-The Boss- Posted January 3, 2011 Share Posted January 3, 2011 Really, why give the OP a hard time for this, if it is in the wrong forum then the mods will take care of it. No comment on the Walmart oil or the weight/viscosity you are using. The OP should Learn MODs Move this It runs Link to comment Share on other sites More sharing options...
