Bigdaddy41301 Posted September 4, 2011 Share Posted September 4, 2011 My oil pressuer light came on at start up and stayed on for about 5 or 6 miles and then went off. When my wife got home she told me about it and i went out to look when i started the car the light came back on.First thing i did was check the oil and it is full and still clean from the oil change 2 weeks ago. I am thinking oil pump maybe but i dont know what do you guys think? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 4, 2011 I Donated Share Posted September 4, 2011 likely problems with the oil pressure sending unit. could be a bad oil pump, clogged oil port, bottom end problems, low quality oil, etc. If that light is on, you should NOT run the car. Lack of oil pressure will destroy the internals of the engine. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted September 4, 2011 Share Posted September 4, 2011 Yeah. IT is not fun. :/ Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 4, 2011 I Donated Share Posted September 4, 2011 ^Jab would know. Did you have an oil pressure light come on when your bottom end tore up? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 She drove it about 10 or 12 miles from the time the ligt came on and we parked it now time to figure out the problem. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 Where is the oil sending unit? Link to comment Share on other sites More sharing options...
Jab83 Posted September 4, 2011 Share Posted September 4, 2011 It wouldn't stay on. It'd like come on every now and then. then would turn off @_@ thats why i didn't worry. LOL then On my way to a big job interview it blew. lol. with me driving like a grany cause i was almost out of gas. LOL Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 first time mine has been on and from the research sounds like the oil pump going out is very un likely so yeah prob the oil pressure switch but i cant find anywhere with a diagram or picture or video that shows me where it is located? Link to comment Share on other sites More sharing options...
Jab83 Posted September 4, 2011 Share Posted September 4, 2011 I've no idea. I wonder if thats what happened to mine. LOL. Dont kill it like i did. :/ Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 I hope not i just put this motor in about 900 miles ago. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 Another questions is if i put on a new oil pressure switch/sender and it fixes it will the light go out or will i have to disconnect the battery? Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 4, 2011 Share Posted September 4, 2011 The light will go out...does anyone know why an oil light would come on at really low rpms, like 700 and less. Only a hot idle, but turns right off as soon as the gas is touched or if I let off the clutch. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 Even 2 psi change will cause the light to come on it was suggested on antoher forum to unplug the pressure switch and see if the light stays off if so it is a short in the cicuit or oil pressure switch is bad. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 4, 2011 I Donated Share Posted September 4, 2011 If you unplug the sensor, the light will stay on......not stay off....because the ECU will be getting no return signal from it.....and it will assume that there is NO oil pressure at all. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 Is there any way to test it without just putting on a new one then? I think it won't matter because i noticed some oil under the car i think i have a bigger problem. But it has been leaking since i had the new motor put in but only for a few minutes after you drive the car don't know if it is related or not. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 Will it not hurt the engine to run while i do a pressure test if the pump is bad? Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Author Share Posted September 4, 2011 Never mind i'll figure it out. Link to comment Share on other sites More sharing options...
johnegg Posted September 4, 2011 Share Posted September 4, 2011 did you reseal the oil pump and tighten the screws on the back side of the pump when you installed the engine? my guess that is your problem. the screws loosen and back out over time and then the pump does not pump as it should. is the oil leak from the 2 doo-dads (technical term) hanging down on the very front center of the engine? that is the oil pump. Link to comment Share on other sites More sharing options...
killerbmotorsport Posted November 6, 2011 Share Posted November 6, 2011 I know this is an old thread, but did you ever find out what was wrong? OEM pressure light comes on a 2.1psi. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted November 11, 2011 Author Share Posted November 11, 2011 It was the oil pressure sending unit sorry it took me so long to respond. Link to comment Share on other sites More sharing options...
A.J. Tarnas Posted July 11, 2013 Share Posted July 11, 2013 Apparently the wire has been disconnected for my oil pressure sending unit. No gauge light or ODB code as a result, though. Link to comment Share on other sites More sharing options...
killerbmotorsport Posted July 12, 2013 Share Posted July 12, 2013 ^ Correct. It's a 'normally open' switch so unplugging it is the same thing as it operating normally. It's also not connected to the ECU in any way even on newer cars. Link to comment Share on other sites More sharing options...
johnegg Posted July 12, 2013 Share Posted July 12, 2013 plug it in, and check the oil. Link to comment Share on other sites More sharing options...
