Abandonhope16 Posted August 21, 2006 Share Posted August 21, 2006 Just wondering if anyone would be willing to help me with a boost gauge install. I was going to do it myself, but I want to mount it on the steering column and that may turn out to be a bit complex for me. Thanks all. Link to comment Share on other sites More sharing options...
rallispec Posted August 21, 2006 Share Posted August 21, 2006 do you have a mount for it? (btw, it sounds worse than it is -- boost gauges are pretty easy to install -- thier is a very good walkthrough on here somewhere) Link to comment Share on other sites More sharing options...
Abandonhope16 Posted August 21, 2006 Author Share Posted August 21, 2006 Yeah, I have a mounting bracket. Link to comment Share on other sites More sharing options...
rallispec Posted August 21, 2006 Share Posted August 21, 2006 I'm assuming you're main concern is tapping into and routing the vacuum line?.. once you get that done, the only thing left is figure out where you're going to get power from - which isn't too bad. If you haven't tackled it by this weekend I can give you a hand... You've got the prosport gauge, right? I'm curious to see how it looks. I ordered mine in the group buy but recieved the wrong color (the hyper blue instead of amber) -- looked close enough to what i wanted that I didnt bother returning it. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted August 21, 2006 Author Share Posted August 21, 2006 Yeah, its the prosport. Pretty much concerned about running and connecting any wires/tubes. Thanks a bunch, I really appreciate it. I'll let you know. I'd probably try for something on Saturday morning b/c I'm going to have to be up early anyway. Link to comment Share on other sites More sharing options...
Daedalus Posted August 21, 2006 Share Posted August 21, 2006 I have to do mine soon also. Prosport in the AVO pod. Link to comment Share on other sites More sharing options...
rallispec Posted August 21, 2006 Share Posted August 21, 2006 i got a very cheap column mount off of ebay... Looks kind of ghetto (very minimalistic) but whatever.. i'm cool with it. ANd i've decided i'm not going to put any more money into the car unless it's for maintenance reasons... at least for now. Link to comment Share on other sites More sharing options...
PeterJMC Posted August 22, 2006 Share Posted August 22, 2006 I installed my boost gauge today. All in all, it took less than an hour to install. It was a VERY simple install. It just took me awhile because I didn't have all the parts I needed the first time I started the install, and I was looking for different ways to route the vac line through the firewall. Link to comment Share on other sites More sharing options...
rallispec Posted August 22, 2006 Share Posted August 22, 2006 the easiest way that i found is through the gasket in the wheel well. the prosport gauges came with a "T" fitting, correct? Link to comment Share on other sites More sharing options...
Abandonhope16 Posted August 22, 2006 Author Share Posted August 22, 2006 It comes with the "T". But it is my understanding that the tubing supplied isnt enough. I have a little over 6ft. I tried to get some more last night, but it wasn't exactly the same. Link to comment Share on other sites More sharing options...
rallispec Posted August 22, 2006 Share Posted August 22, 2006 yeah - you will need a longer peice of tubing -- I went to autozone and they have a large selection of vacuum hose to choose from. (black rubbery tubing - not clear like the stuff that comes with the gauge) I can't remember which diamter i went with - but it's got to be small enough to fit snug on the gauge.. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted August 22, 2006 Author Share Posted August 22, 2006 I tried Advance and they didnt have anything. I even tried Home Depot b/c it was relatively close and they had the tubing that is typically used for friges, which I guess could techically work; but the inside diameter was a little bigger and the wall was a little thinner. So to be safe I want to go with something as close to what I was supplied with as possible. Too bad the closest Autozone is 20ish miles away from me. For some reason we only have these small auto parts stores around me with a relatively limited selection. Link to comment Share on other sites More sharing options...
Daedalus Posted August 22, 2006 Share Posted August 22, 2006 Where abouts do you live? Link to comment Share on other sites More sharing options...
Abandonhope16 Posted August 22, 2006 Author Share Posted August 22, 2006 Right near Tyson's Corner, off Rt. 7 Link to comment Share on other sites More sharing options...
Daedalus Posted August 22, 2006 Share Posted August 22, 2006 There is an Advanced Auto Parts off of Chainbridge inside the Beltway. There is another near Fairfax Circle off of 29 and 50. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted August 22, 2006 Author Share Posted August 22, 2006 I went to an advanced in Sterling and had no luck, probably b/c it was a really small shop. I'll probably try some of the other places around me. Link to comment Share on other sites More sharing options...
rallispec Posted August 24, 2006 Share Posted August 24, 2006 anybody else have anything they're sitting on waiting to install? Link to comment Share on other sites More sharing options...
sandwood Posted August 24, 2006 Share Posted August 24, 2006 I've got a major swap coming up - taking off my FMIC and doing a turbo and injector swap. will be in my garage in DC, probably mostly on the weekend of Sept. 10th. I'll post about it closer to the date, but if anyone is interested in helping out, free food and beer for you! getting out of the legacy game Link to comment Share on other sites More sharing options...
Daedalus Posted August 24, 2006 Share Posted August 24, 2006 anybody else have anything they're sitting on waiting to install? I need to regrease my MSI endlinks, install my AVO pod and Prosport gauge, and install my Whiteline steering rack bushings once I pay Highwaydrifter and get them from PatagonianGT. Link to comment Share on other sites More sharing options...
jthewood Posted August 25, 2006 Share Posted August 25, 2006 anybody else have anything they're sitting on waiting to install? I need to get my garage installed! As soon as that's done, I'll be happy to help with mods.... Link to comment Share on other sites More sharing options...
rallispec Posted August 25, 2006 Share Posted August 25, 2006 heh.. yeah the garage helps. I've got the garage (although, i'm not sure that a car could actually fit in it) -- but i've got no tools... another necessity... i'm looking forward to having another full fledged install day this fall once things cool down a bit.... hopefully Steve will be up for hosting again. (steve's the man and his house rocks.. i just want to move in to his garage ) Link to comment Share on other sites More sharing options...
jthewood Posted August 25, 2006 Share Posted August 25, 2006 I'm there for an install day. I don't have anything to install, nor any money to purchase anything to install, but I'll come watch and supervise. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted August 25, 2006 Author Share Posted August 25, 2006 Finally got the vac hose. It only took 4 Advance Auto Parts and a trip to Germantown md. Everything fits snuggly, I'm just hoping its not too thin/small; ie the air will be able to pass through without creating too much pressure, causing the tube to burst. I hope. Anyway, I got 7/64; may be a bit smaller than the one the gauge came with. Link to comment Share on other sites More sharing options...
rallispec Posted August 26, 2006 Share Posted August 26, 2006 who was that at starbucks this morning? (what were the chances of that happening?) Link to comment Share on other sites More sharing options...
