bocard80o Posted April 7, 2013 Share Posted April 7, 2013 Hello i am new to the forums and this is my first subie she is a 1995 subaru legacy L she has 251000 miles on her and still running strong, i recently had the passenger wheel bearing replaced, got a full tune up, transmission service and new muffler and exhaust pipping. even with the wheel bearing issue i drove her for a while and she never gave me a issue. but i do have one concern that im hoping you guys can share your expertise on. i recently scanned a engine check light and the only thing that came up was the knock sensor. how important is the knock sensor and can it have a big impact on my car if not fixed right away? Also as i said my car drives fine with no issues but when she is idle at times she seems sputtery and jumpy like she may want to shut off but she never has. during the tune up sparks plugs and wires were changed and this issue still remains. what could it be? can it be related to the knock sensor. Thanks in advance guys! Link to comment Share on other sites More sharing options...
pleaidestar Posted April 7, 2013 Share Posted April 7, 2013 Knock sensor is pretty important as well as really easy to replace..a bad knock sensor can make the motor detonate or misfire, good to take care of it asap they are like 25-40 bucks and take 15 minutes to replace. Link to comment Share on other sites More sharing options...
bocard80o Posted April 7, 2013 Author Share Posted April 7, 2013 Thanks for your insight. Could this be the reason I feel that sputtering or shutting of feeling during idle? I'm not sure where to find the knock sensor I was told its under the intake Sent from my Galaxy Nexus using Tapatalk 2 Link to comment Share on other sites More sharing options...
pleaidestar Posted April 7, 2013 Share Posted April 7, 2013 ..forgot a detail, there are torque specs too, I believe it should be torqued down at 14 lbs. Link to comment Share on other sites More sharing options...
pleaidestar Posted April 7, 2013 Share Posted April 7, 2013 Its located on the block on the driver side under the throttle body and has a wire connection and a #12 bolt through it to fasten to the block.... That's probably the exact reason it sputtering, its telling the ecu to correct fueling. Link to comment Share on other sites More sharing options...
bochuck Posted April 7, 2013 Share Posted April 7, 2013 With age hoses deteriorate. I would have a vacuum test done. My guess is that you have a leak somewhere. VF-52 and all associated bits tuned by Tuning Alliance. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 7, 2013 Share Posted April 7, 2013 id probably just check the hoses before a full out vacuum test, a loose or leaking hose frequently contributes to a variable idle.. then clean your MAF. Link to comment Share on other sites More sharing options...
bocard80o Posted April 7, 2013 Author Share Posted April 7, 2013 I'm not sure where to purchase the sensor a mechanic was trying to charge me $160 just to do the sensor..I said hell nooo Lol. Sent from my Galaxy Nexus using Tapatalk 2 Link to comment Share on other sites More sharing options...
snederhiser Posted April 7, 2013 Share Posted April 7, 2013 Hello; Knock sensor is very important, look on ebay, fourteen dollars sent to your door! Other members have reported good luck on these. Steven. Link to comment Share on other sites More sharing options...
bochuck Posted April 7, 2013 Share Posted April 7, 2013 The OEM part from Subbie costs around 90 bucks brand new. Take your pick on which one you want I guess. Is that the installed price or just for the part? VF-52 and all associated bits tuned by Tuning Alliance. Link to comment Share on other sites More sharing options...
bocard80o Posted April 7, 2013 Author Share Posted April 7, 2013 Installed price Sent from my Galaxy Nexus using Tapatalk 2 Link to comment Share on other sites More sharing options...
pleaidestar Posted April 7, 2013 Share Posted April 7, 2013 160 bucks =1 hr labor+cost of part from local store+ tax Link to comment Share on other sites More sharing options...
bocard80o Posted April 7, 2013 Author Share Posted April 7, 2013 If its a easy diy I figure I'll try and do it myself. Can anyone post a link to the sensor on ebay Sent from my Galaxy Nexus using Tapatalk 2 Link to comment Share on other sites More sharing options...
pleaidestar Posted April 8, 2013 Share Posted April 8, 2013 Its easy trust in the 6" 3/8 drive wobbly extension, ratchet and #12 socket Link to comment Share on other sites More sharing options...
Zues Marine Posted April 8, 2013 Share Posted April 8, 2013 because typing 'ej25 knock sensor' into ebay is too hard: http://www.ebay.com/sch/i.html?_odkw=3ej25+knock+sensor&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0&_nkw=ej25+knock+sensor&_sacat=0 Link to comment Share on other sites More sharing options...
bocard80o Posted April 8, 2013 Author Share Posted April 8, 2013 I was just reading this : Depending on the make and model of your car, replacing a knock sensor can be very expensive. It is cheaper to replace it yourself but is very time-consuming and only recommended if you have a knowledge about automobiles. Some models have the knock sensor stored inside the engine block, in which case the radiator coolant would need to be drained. The sensor must also be torqued to exact specifications or it will be too sensitive to vibration and harm engine performance or not work at all. Refer to your owner's manual for the specifics on your engine. Have any idea if the torque issue has to be done on the legacy or how to do it? Sent from my Galaxy Nexus using Tapatalk 2 Link to comment Share on other sites More sharing options...
Zues Marine Posted April 9, 2013 Share Posted April 9, 2013 here, just do this. Link to comment Share on other sites More sharing options...
pleaidestar Posted April 9, 2013 Share Posted April 9, 2013 Good job zues, didn't know a diy was available for that Can't get any easier than that... Link to comment Share on other sites More sharing options...
bocard80o Posted April 9, 2013 Author Share Posted April 9, 2013 Thanks a lot guys ! Still confused on the torque issue cause I want it too be aligned correctly but everything else is self explanatory. Sent from my Galaxy Nexus using Tapatalk 2 Link to comment Share on other sites More sharing options...
pleaidestar Posted April 9, 2013 Share Posted April 9, 2013 ..forgot a detail, there are torque specs too, I believe it should be torqued down at 14 lbs. One more time. Link to comment Share on other sites More sharing options...
bocard80o Posted April 9, 2013 Author Share Posted April 9, 2013 Thanks guys I'm a newbie to subies i be been a Honda guy previously Sent from my Galaxy Nexus using Tapatalk 2 Link to comment Share on other sites More sharing options...
