DAP Posted October 15, 2005 Share Posted October 15, 2005 Light tan interior, sun shining in the rear window, dark trees behind me, I get so much glare from the rear shelf reflecting off the rear window, it is hard to see where I am going when I'm backing out of my garage in the morning. I'm very tempted to replace the rear shelf parts with those from the charcol interior, but I havn't been able to see these parts to tell if they are dark enough to actually improve the situation. Are they grey which won't help much, or black? I'm hoping they are at least as dark as the front dash board. Link to comment Share on other sites More sharing options...
Brady Posted October 15, 2005 Share Posted October 15, 2005 looks to me you just need to clean the rear window well, inside and out. Looks more hazy to me. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 15, 2005 Share Posted October 15, 2005 Sunglasses. Link to comment Share on other sites More sharing options...
dan_m Posted October 16, 2005 Share Posted October 16, 2005 back the car up your driveway when you get home that way you get to show off your scoop as a bonus too Link to comment Share on other sites More sharing options...
meier motor sports Posted October 16, 2005 Share Posted October 16, 2005 clean your window thoroughly:) Link to comment Share on other sites More sharing options...
StringFellow Posted October 16, 2005 Share Posted October 16, 2005 Light tan interior, sun shining in the rear window, dark trees behind me, I get so much glare from the rear shelf reflecting off the rear window, it is hard to see where I am going when I'm backing out of my garage in the morning. I'm very tempted to replace the rear shelf parts with those from the charcol interior, but I havn't been able to see these parts to tell if they are dark enough to actually improve the situation. Are they grey which won't help much, or black? I'm hoping they are at least as dark as the front dash board. If you drive with your windows down much, the rear window will always get that haze well before other windows. Use Stoners Invisible Glass Cleaner to clean your rear window inside and out. Should solve your problem. -S Link to comment Share on other sites More sharing options...
Boulderguy Posted October 17, 2005 Share Posted October 17, 2005 If you drive with your windows down much, the rear window will always get that haze well before other windows. Use Stoners Invisible Glass Cleaner to clean your rear window inside and out. Should solve your problem. -S Why is that? Something to do with the "new car smell" that fogs the windows? Link to comment Share on other sites More sharing options...
TSiWRX Posted October 17, 2005 Share Posted October 17, 2005 http://legacygt.com/forums/showthread.php?t=19264&highlight=stoner%27s Most good cleaners will help you with this situation, however, it will continue to recur, and that recurrence will depend heavily on your vehicle and its unique "blend" of plastics that's evolving the dreaded vapors , your A/C usage, as well as just the alignment of the stars. Best bet? When you notice the "haze," give your windows a good wipe-down with a dry, clean, microfiber cloth. I typically can go about a week or so of haze-free using the Stoners cleaner. Best of luck! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
DAP Posted October 17, 2005 Author Share Posted October 17, 2005 The problem is there even when the glass is clean, but dirt does make it worse. Traffic is not a problem where I live, but I still don't like backing up blind. Link to comment Share on other sites More sharing options...
