05gtwannabe Posted July 30, 2014 Share Posted July 30, 2014 Looked around - but can't find answer to this. I want to buy H and R springs with my new KYB gt2 struts. Can I do this without any other modification? I.E.- caster/ camber additions? I know I will need an alignment bc I will be taking out front struts. Thanks! Anyone have any pics of this setup? Link to comment Share on other sites More sharing options...
05gtwannabe Posted July 30, 2014 Author Share Posted July 30, 2014 Forgot to mention - the spring I will be getting are supposed to drop it 1.5" f and R. Am getting 17" 2007 wrx wheels This week- should I have any rubbing/ clearance issues? Thanks! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 30, 2014 Share Posted July 30, 2014 Looked around - but can't find answer to this. I want to buy H and R springs with my new KYB gt2 struts. Can I do this without any other modification? I.E.- caster/ camber additions? I know I will need an alignment bc I will be taking out front struts. Thanks! Anyone have any pics of this setup? No mods needed they will fit. I installed H-Techs and KYBs on my 2.5i and dialed in half degree of negative camber. Link to comment Share on other sites More sharing options...
05gtwannabe Posted July 30, 2014 Author Share Posted July 30, 2014 No mods needed they will fit. I installed H-Techs and KYBs on my 2.5i and dialed in half degree of negative camber. So you mean front camber - correct? Which shop does at alignment- correct? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 30, 2014 Share Posted July 30, 2014 You can adjust your camber in the dirveway but at the time of your alignment you can ask the shop to dial in specific settings. On the front you cant miss the 19mm camber bolts (the bottom bolt) it has tick marks half are for + the other for - i used the middle mark. In the rear the rear the bolts are in the lower control arms you cant miss these either. Link to comment Share on other sites More sharing options...
