Yamba6 Posted January 7, 2014 Share Posted January 7, 2014 I have an 05 legacy gt and have been hearing a noise coming from what sounds like the Passenger side front wheel. This sound happens when the tire is spinning freely on snow with me giving it gas. The sound almost has that ABS pulsing sound when it happens. It only happens when I turn the wheel (I believe to the left) I'm not sure if its a differential or cv shaft. Anyone have any issues with something like this before? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 7, 2014 Share Posted January 7, 2014 Front wheel bearing/hub assembly. Only replace it with a OEM one. Read the DIY on front wheel bearings. http://legacygt.com/forums/showthread.php/front-wheel-bearing-diy-walkthrough-86994.html Oh welcome to the forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Yamba6 Posted January 7, 2014 Author Share Posted January 7, 2014 I mean I've heard a wheel bearing before on several cars because of how hard I corner in them..... this sounds literally like ABS/grinding. Not a hum.... its more happens when I spin the tires as well, which I'm guessing would have less weight on the bearing at that time since I'm sliding and not grabbing traction. Edit: sorry, thank you for the welcome. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 7, 2014 Share Posted January 7, 2014 From the way you say you drive it. it could be the center diff ?If know one else chimes in PM, m sprank, or GTTuner. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Yamba6 Posted January 7, 2014 Author Share Posted January 7, 2014 Thank you, will do. I have a bad feeling that's what it is. Its only when I spin tires while drifting it to the right. Link to comment Share on other sites More sharing options...
