ChefRacer Posted April 26, 2012 Share Posted April 26, 2012 So I've been trying to retrieve my map off of my ecu using ecuflash, but I can't get it to recognize the cable. How do I setup the port for the cable with ecuflash? Romraider syncs up just fine but ECUflash won't hook up to the ecu. I'm most likely just missing something stupid. Thanks Link to comment Share on other sites More sharing options...
90G60 Posted April 26, 2012 Share Posted April 26, 2012 I'm having the same problem. Going to try the older version of ECU flash that came with the vagcom cable. If Romraider recognizes the cable and can read your ECU, you have the drivers for the cable installed correctly. The error I'm getting leads me to believe there is an issue with the ECU definitions. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted April 26, 2012 Mega Users Share Posted April 26, 2012 Did you direct ecuflash to the right port? Link to comment Share on other sites More sharing options...
ChefRacer Posted April 26, 2012 Author Share Posted April 26, 2012 I don't know how to direct ecuflash to the right port, there is no option in the options menu. Link to comment Share on other sites More sharing options...
ChefRacer Posted April 30, 2012 Author Share Posted April 30, 2012 How can a change the port that ECUflash is directed to? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 30, 2012 Moderators Share Posted April 30, 2012 Try manually selecting the vag-com to operate under com port 1 (in device manager). Check if ECU Flash works. You may have to change the COM in LV or RR for those to work (these are drop down menus). Also, I BELIEVE you need the older version of ECUFlash...check the sticky in the top of the tuning section, there's a link I think. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted April 30, 2012 Mega Users Share Posted April 30, 2012 For some reason I thought there was a way to change it. Now that I look, I guess there isn't. Gotsugg had the same problem here: http://legacygt.com/forums/showthread.php/ecuflash-not-working-but-romraider-123595.html Did you set up the baud rate for the port to 4800? Green test connectors connected? NSFW said in that thread to disable all of the other ports and see if ecuflash finds it. Link to comment Share on other sites More sharing options...
MasAyinde Posted May 1, 2012 Share Posted May 1, 2012 Chef and I tried this combination a bunch of times. The cable isn't the problem, it's 100% his laptop. I plugged his cable into my laptop and it worked fine. We even reinstalled it and redownloaded the drivers and it still wouldn't work. At the time, I was stumped. Link to comment Share on other sites More sharing options...
ChefRacer Posted May 1, 2012 Author Share Posted May 1, 2012 I'm using a diff laptop now though, so lv and rr work fine atm. Link to comment Share on other sites More sharing options...
