Justin3390 Posted September 3, 2011 Share Posted September 3, 2011 Hey guys, I have an 07 LGT that I've had for about 3 weeks. It's also my first Subaru. I absolutely love it, but i have a problem. If I have my radio on and I turn on the rear defrosters the stations turn into static. Has anyone else had this problem? Please help because the dealer I bought the car from won't. I've been getting dicked around since I bought it and I'm fed up with them. Link to comment Share on other sites More sharing options...
subielova88 Posted September 3, 2011 Share Posted September 3, 2011 There is a Technical Service Bulletin about that somewhere. I have the same problem in my car. I'll try and find the information for you. Link to comment Share on other sites More sharing options...
Justin3390 Posted September 4, 2011 Author Share Posted September 4, 2011 Someone told me there might be a crack in one of the grids on the back window. I guess permatex sells a window grid repair kit. The tough part is finding the crack. It could be a big, noticeable one. Or a very small one that you need a magnifying glass to find. This should be a lot of fun Link to comment Share on other sites More sharing options...
RJS5689 Posted September 8, 2011 Share Posted September 8, 2011 It's also important to note this problem isn't Subaru specific. Any car can have this type of issue. For what it's worth, my Subaru currently does the same thing. Link to comment Share on other sites More sharing options...
tito_b0y Posted September 8, 2011 Share Posted September 8, 2011 I never had this issue until I had tints put on, 5% in the rears to be exact. Not really a problem since I listen to my iPod 99% of the time. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
ksnh Posted September 10, 2011 Share Posted September 10, 2011 Hey guys, I have an 07 LGT that I've had for about 3 weeks. It's also my first Subaru. I absolutely love it, but i have a problem. If I have my radio on and I turn on the rear defrosters the stations turn into static. Has anyone else had this problem? Please help because the dealer I bought the car from won't. I've been getting dicked around since I bought it and I'm fed up with them. "Customer complaint of radio static when the radio and rear window defogger are on at the same time, there is the possibility of a break in one or more of the defogger grids. When the grid is broken, a high resistance field is created at the break point which can create static on some radio stations. The level of resistance is usually high enough to create a field of interference which projects out from the glass. The break can be detected visually or by using a portable radio. Using a portable radio, set the radio to the same frequency and station being disturbed by static. From the outside of the vehicle, slowly move the radio’s antenna across the defogger grids. When interference is encountered, inspect that specific area closely for a break. Depending upon the size of the break, a magnifying glass and/or eyeloupe may be required. Once the break is identified, it should be repaired using the Permatex® repair kit instead of replacing the rear glass. Note: Make sure to carefully read and follow the instructions and precautions that are included with the Permatex® repair kit. Permatex® Quick Grid™ Rear Window Defogger Repair Kit, part # 15067, used for repairing damaged rear window defogger grids, is available at local automotive parts stores." Link to comment Share on other sites More sharing options...
GTTuner Posted September 10, 2011 Share Posted September 10, 2011 I only get static when my brake lights are on. I think it's the 48 SMD LED bulbs I'm running in there. Link to comment Share on other sites More sharing options...
subielova88 Posted September 10, 2011 Share Posted September 10, 2011 Someones got access to alldata lol (ksnh) Link to comment Share on other sites More sharing options...
inycxkid Posted October 3, 2011 Share Posted October 3, 2011 Damn problem just happened to me recently too Link to comment Share on other sites More sharing options...
Justin3390 Posted October 5, 2011 Author Share Posted October 5, 2011 Damn problem just happened to me recently too i got my rear window replaced and it fixed the problem........thank you insurance Link to comment Share on other sites More sharing options...
