My BNR68 LGT dyno tune with vid
Event: Dyno Pull
Loaction: JS Dyno, Verona PA
Date: 8/3/12
Ambient Temp: 95 degrees F
Elevation: Approx. 760ft
Weather: Sunny, humid
Car: 2005 Subaru Legacy GT
Tuner: Nate Silveri, TPG Tuning
Dyno Info: Mustang
Transmission: 5speed
Gear: 3rd or 4th
Peak Horse Power at RPM: 308@ approx. 5600rpm
Peak Torque at RPM: 313@ approx. 4600rpm
Baseline hp/tq for a stock on same dyno: stock STI makes around 210
Target Boost: 18.5-19psi
Target AFR: 11ish
SAE Correction factor: ??
Fuel: Shell V-power 93 octane
Engine/Power Modifications: BNR68 turbo w/upgraded actuator, ITSME FMIC, 73mm intake, Gimmick turbo inlet tube, Grimmspeed EBCS, Perrin recirc valve, Equal length header, Catless Up pipe, CNT catless downpipe, X02 exhaust, Grimmspeed exhaust gaskets,TGV deletes, Five-0 850cc sidefeeds, Walbro 255,
Driveline Modifications: ACT clutch w/wrx singlemass flywheel, Group-N trans mount
Suspension Modifications: ISC N1 coilovers with updated shorter rear struts and lower strut mounts, Whiteline 20mm adjustable rear sway bar
Other Modifications: 17x9 Rota Grids with stock size tires
http://i143.photobucket.com/albums/r139/95legend_type2/05%20Legacy%20GT/D82C1682-D30E-4B8E-8749-1881201E3A58.jpg
http://i143.photobucket.com/albums/r139/95legend_type2/05%20Legacy%20GT/6C9CE7BD-FEF6-4627-A4B6-2C0EC7831788.jpg
http://i143.photobucket.com/albums/r139/95legend_type2/05%20Legacy%20GT/414FF8D8-DFC5-4C3A-BEF0-6B4CD1A6599D.jpg
http://i143.photobucket.com/albums/r139/95legend_type2/05%20Legacy%20GT/B14C88F9-6B02-458E-8E0D-0A2F2ECBE66D.jpg
http://i143.photobucket.com/albums/r139/95legend_type2/05%20Legacy%20GT/CF7F2845-F4A5-436B-9D7F-F1CA4079D928.jpg
Here is a video, this isnt the final pull, but the only vid I got, click the pic to see it.
http://i143.photobucket.com/albums/r139/95legend_type2/05%20Legacy%20GT/th_legacy1-1.jpg
Nate told me since I'm on a stock longblock this is the most he wanted to push it, he told me there is alot more room for power. I'm very happy with it, has crazy top end, holds target boost the whole way to redline.
Why the low boost? And a seemingly late spool. Looks like a very low reading dyno though if a stock sti is a 210whp... I bet you'd be in the 330-340whp range on a more 'normal' dyno.
Was it 3rd or 4th gear? If that graph is from 4th gear I would be pretty upset about the spool. If it is from 3rd gear its a bit more reasonable. Either way hope you're enjoying the car.
lol
Doh... that explains it :lol:
I missed that at the bottom of your pictures
lol
the 68's love 20+ psi, that seems to be their sweet spot.
and FFS how tight did they strap your rear end down? DIS AINT NO GARRETT 40R
It definitely isnt in its sweet spot yet but its safe. Thats pretty much how to car sits all the time in the back, it was super close to rubbing but all went well, the dudes that strapped it down were getting all pissed cause they thought it was going to rub.
