SpecBGuy Posted March 30, 2012 Share Posted March 30, 2012 so i got a ebay grille off of a member here after ravspec honeycomb didnt work out. first thing was to make sure the grille fits. i had to cut some of the mesh off for it to slide into place. the mold did not come with pre drilled holes but does have a dent or something to show you where to drill. i started off making a small hole and worked my way up just to make sure the holes lined up which matched perfectly. theres like a hook think on the bottom of the grille that matches up with the screw hole from the oem grille. i drilled a small hole there and tightened with the oem screw. thats all the drilling and cutting i did not much imo. theres a small bump in the from near the mesh which i can sand down but after installing the grille i was too lazy to take it off and do it. if any of you are planning to get this i would recommend getting a honeycomb grille mesh from Ford and then install it. the mesh on this seems cheap and weak. this is just a quick pic i took on the street. Link to comment Share on other sites More sharing options...
Dwreck Posted March 30, 2012 Share Posted March 30, 2012 Looks nice and clean! Did the grille come pre-painted? If not, what color plastic? Link to comment Share on other sites More sharing options...
charlie_sheen Posted March 30, 2012 Share Posted March 30, 2012 honestly, that looks.......not bad. im impressed, how much did it run you? Link to comment Share on other sites More sharing options...
SpecBGuy Posted March 31, 2012 Author Share Posted March 31, 2012 well done. the ford honeycomb method also requires alot of cutting to make it fit inside properly. you could do the crown vic mod to that grille-- the ford honeycomb generally sits closer to front of grille. the hardest part is attaching it firmly to shell of grille.... maybe you could lay the ford honeycomb over that mesh? some gardening shears really simplifies cutting the ford honeycomb to shape. planning to do honeycomb later on for now I'm too lazy. Attaching the honeycomb in front of the mesh sounds like an idea I will keep that in mind. honestly, that looks.......not bad. im impressed, how much did it run you? $100 from member here. Ebay has it for $120-160 not sure. Looks nice and clean! Did the grille come pre-painted? If not, what color plastic? The grille came black not sure if its mold color or painted. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 31, 2012 Share Posted March 31, 2012 That does look good, nice job. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted March 31, 2012 Share Posted March 31, 2012 Looks nice. Wonder how it would look on our car? Link to comment Share on other sites More sharing options...
SpecBGuy Posted March 31, 2012 Author Share Posted March 31, 2012 thanks, this i think is the cheapest new grille you can find out there. im going to look into a subaru emblem, the front just looks empty with out one. i dont know if they sell these for 05 models but i think it will look nice or even better since your grilles arent big as 08+ models. Link to comment Share on other sites More sharing options...
kgkjack Posted April 2, 2012 Share Posted April 2, 2012 i think i have the same grill it was poorly packaged and cracked when i got it. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted April 2, 2012 Share Posted April 2, 2012 thanks, this i think is the cheapest new grille you can find out there. im going to look into a subaru emblem, the front just looks empty with out one. i dont know if they sell these for 05 models but i think it will look nice or even better since your grilles arent big as 08+ models. Pretty sure I have that same grille from Ebay for an '05. Replaced the flimsy mesh with black powder coated aluminum Razr pattern from thegrilleguy off Ebay. For a while I had an L7 badge up front. Now I just have the GT (from my debadging) in the right lower corner. Had it for a # of years and it has held up well so far. Link to comment Share on other sites More sharing options...
SpecBGuy Posted April 2, 2012 Author Share Posted April 2, 2012 Pretty sure I have that same grille from Ebay for an '05. Replaced the flimsy mesh with black powder coated aluminum Razr pattern from thegrilleguy off Ebay. For I while I had an L7 badge up front. Now I just have the GT (from my debadging) in the right lower corner. Had it for a # of years and it has held up well so far. i never knew they even sold lgt grille on ebay or i never bothered checking it needs some kind of badge cuz it looks too plan imo. i think i have the same grill it was poorly packaged and cracked when i got it. it could of been UPS or some idiot who messed up your box, but then again the box shipped wasnt that durable looking either. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 2, 2012 Share Posted April 2, 2012 I like how the mesh sits back in the recess. The current one on ebay for a 05 on the red car looks like it sit near the front. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted April 8, 2012 Share Posted April 8, 2012 Mine: Link to comment Share on other sites More sharing options...
lucas569 Posted April 8, 2012 Share Posted April 8, 2012 anyone have a link to this ebay grill? Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted April 8, 2012 Share Posted April 8, 2012 Here's the one I have. http://www.ebay.com/itm/JDM-Subaru-Legacy-Outback-05-06-07-2005-2006-2007-Front-Bumper-Mesh-Grill-Grille-/140696468604?fits=Model:Legacy&hash=item20c229bc7c&item=140696468604&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr Link to comment Share on other sites More sharing options...
theGeneral Posted April 8, 2012 Share Posted April 8, 2012 Dunno guys to me it looks.....empty, like someone stole your grill. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted April 8, 2012 Share Posted April 8, 2012 What kind of crazy monkey would steal something with a big ugly chrome wing on it? Link to comment Share on other sites More sharing options...
SpecBGuy Posted April 9, 2012 Author Share Posted April 9, 2012 Dunno guys to me it looks.....empty, like someone stole your grill. yeah i know what you mean. when i saw pics of lgt with grilles like this i thought it looked like something was missing. but this is why you need to change the mesh to honeycomb and add some kind of badge on it. Mine: ebay grille and ebay lip:p Link to comment Share on other sites More sharing options...
SpecBGuy Posted April 9, 2012 Author Share Posted April 9, 2012 What kind of crazy monkey would steal something with a big ugly chrome wing on it? its monkey business Link to comment Share on other sites More sharing options...
ssbtech Posted April 9, 2012 Share Posted April 9, 2012 A good way to add style to any car is to remove the styling elements it came with. It's just a big black hole Link to comment Share on other sites More sharing options...
nospmoht04 Posted April 9, 2012 Share Posted April 9, 2012 I'm making my own from scratch out of a stock grill right now. Gonna put my specB badge off centered to the right. I cut out all the emblem surroundings and wings and filled it in with an epoxy type material and did a lot of sanding. Took some work but it's comin out great. I'll post pics later of it. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted April 10, 2012 Share Posted April 10, 2012 ebay grille and ebay lip:p You're batting .500, RavSpec lip, but I'm too low for the winters here Link to comment Share on other sites More sharing options...
nospmoht04 Posted April 10, 2012 Share Posted April 10, 2012 A good way to add style to any car is to remove the styling elements it came with. It's just a big black hole To each his own I suppose, but if you recess it in with mesh and add either a subie emblem in the center or a GT/SpecB badge off to the right, I think it looks a lot more aggressive. Seperates you from the norm, which I think is the goal of modifying your car. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted April 10, 2012 Share Posted April 10, 2012 To each his own I suppose, but if you recess it in with mesh and add either a subie emblem in the center or a GT/SpecB badge off to the right, I think it looks a lot more aggressive. Seperates you from the norm, which I think is the goal of modifying your car. I agree. Similar to debading the trunk, which I've done as well. I generally have an aversion to chrome though. It all goes back to my '71 Torino GT convertible when I blacked out the bumpers. Actually I've had other emblems up front like the oval L7 or the blue Subaru constellation, but keep coming back to less is more. Link to comment Share on other sites More sharing options...
lucas569 Posted April 10, 2012 Share Posted April 10, 2012 Im just glad it doesnt sag like other grills Link to comment Share on other sites More sharing options...
SpecBGuy Posted April 10, 2012 Author Share Posted April 10, 2012 Im just glad it doesnt sag like other grills how does a grille sag? You're batting .500, RavSpec lip, but I'm too low for the winters here dyanm time for ebay lip now then. i have rommels lip which is handling very well besides a chip i have going up a curve dodging a stupid driver. Link to comment Share on other sites More sharing options...
