beatadrum Posted January 12, 2007 Share Posted January 12, 2007 I recently got a 07 Subaru Legacy 2.5i Limited (which I LOVE!!). Will the same parts that fit on 2.5i that fit on the GT??....If any which ones?? What simple mods would ya'll suggest (besides the obvious of wheels)?? Thanks to all who are helpful!! Especially Sway and Strut bars, Suspension, and Exhaust??? Thanks!! Link to comment Share on other sites More sharing options...
yuhocheung Posted January 12, 2007 Share Posted January 12, 2007 welcome, i have a 06 legacy 2.5i and i installed tein S spring... they work fine. i dont think we can find any performance stuff for the 2.5i yet... all i did were the springs, hid, window tint, debadge and decal... Link to comment Share on other sites More sharing options...
ShockerGT Posted January 12, 2007 Share Posted January 12, 2007 Any GT catback will fit as long as you have an exhaust shop do a little modification. Suspension you can do most things that are available for the GT. Springs, shocks/struts, coilovers, rear sway bar, front sway bar (only if you do a small bit of dremelling on the headers), cusco rear lower brace, strut tower braces. Engine you're pretty much left to low mass pulley and a custom CAI. Weight savings can be seen through wheels, lighter battery (Braille or Oddysey), removing spare, etc. For a brake upgrade, I'd suggest getting a set of GT rotors/calipers or 04 STi calipers/rotors. If you want to do a spring upgrade, I'd suggest getting a set of atleast GT shocks/struts. The 2.5i shocks/struts are even worse than the GT when it comes to stiffer lowering springs. Link to comment Share on other sites More sharing options...
jackacc Posted January 17, 2007 Share Posted January 17, 2007 Yeah as far as the engine goes, not too much. I made an intake for it using the info here in the NA section but I took it off. Definately louder and maybe a little extra pull up top but all in all, I wasn't thrilled. Definately go for a JDM rear sway bar. Relatively inexpensive and what a difference. That and you can usually find decent deals on the JDM Bilstein suspension which is awesome. I put the JDM GT Bilsteins on with pinks in the rear and tanabes up front and it gave me an even drop with exceptional handling. Especially coupled with the JDM rear sway. I had a set of 18" prodrives on for a while then went to the BBS STi wheels and that was a huge difference as well. The BBS were so much lighter and felt more responsive. 18's just give a rougher ride in general. I'm back to the stockers now and I really dig them. Just a few pics to whore out there Before anything: http://www.jacktevnan.com/images/Legacy/subaru%201.JPG After "some things" http://www.jacktevnan.com/images/Legacy/lowered/lowered2.jpg http://www.jacktevnan.com/images/Legacy/BBS/newbbs5.jpg http://www.jacktevnan.com/images/Legacy/intake/finished.jpg JDM GT Bilsteins (F-Tanabe R-Pinks) JDM RSB - Modded Kartboy SS - Subaru Momo Knob Subastyle Grille Link to comment Share on other sites More sharing options...
Guest subiecity Posted January 18, 2007 Share Posted January 18, 2007 yea 2.5i parts...your F***** i tried u aint gonna get any noticable gains, u want real power? floor it going down hill and pretend u have a ferrari,,,,works for me Link to comment Share on other sites More sharing options...
SolidFish Posted January 18, 2007 Share Posted January 18, 2007 right, but what happens once you get to the bottom of the hill? Link to comment Share on other sites More sharing options...
Legacy2.5R Posted January 18, 2007 Share Posted January 18, 2007 well with any luck at the bottom of the hill there is a vendor selling suspension parts....buy all of them and good tires and you will love life. Link to comment Share on other sites More sharing options...
laz Posted January 19, 2007 Share Posted January 19, 2007 The 2.5 is only good for show, but no go. Sometimes I miss the acceleration and smoothness of my old GT. X --- Link to comment Share on other sites More sharing options...
Fudd Posted January 19, 2007 Share Posted January 19, 2007 On sway bars, the front is different for the GT and the 2.5i because of the clearance required for the exhaust manifold. Most companies GT designed fronts will not fit but Whiteline does have one model specific to the 2.5i. I tried to fit a Perrin front but it did not work. I understand the rear is not an issue. Fudd Link to comment Share on other sites More sharing options...
Guest subiecity Posted January 20, 2007 Share Posted January 20, 2007 The 2.5 is only good for show, but no go. Sometimes I miss the acceleration and smoothness of my old GT. X +1 Link to comment Share on other sites More sharing options...
ShockerGT Posted January 20, 2007 Share Posted January 20, 2007 On sway bars, the front is different for the GT and the 2.5i because of the clearance required for the exhaust manifold. Most companies GT designed fronts will not fit but Whiteline does have one model specific to the 2.5i. I tried to fit a Perrin front but it did not work. I understand the rear is not an issue. Fudd You can make them fit. http://legacygt.com/forums/showpost.php?p=845956&postcount=3 Link to comment Share on other sites More sharing options...
OhBe1 Posted January 20, 2007 Share Posted January 20, 2007 Also try rallitek. They've recently added a non-turbo FSB. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
BigJack Posted January 21, 2007 Share Posted January 21, 2007 Also try rallitek. They've recently added a non-turbo FSB. Do you have a link. I don't see it on their site Link to comment Share on other sites More sharing options...
OhBe1 Posted January 24, 2007 Share Posted January 24, 2007 Dang. Now I can't find it. Contact Sean at Rallitek. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
beatadrum Posted January 24, 2007 Author Share Posted January 24, 2007 Yeah I've seen the FSB from Rallitek for a non-turbo, I was just curious....and Gosh everytime I see Jackacc's Legacy I about faint it's the sexiest wagon I've ever seen, although I don't like the BBS wheels, I prefer the PFF7's wayyy better.... Link to comment Share on other sites More sharing options...
Legacy2.5R Posted January 24, 2007 Share Posted January 24, 2007 +1 sexy wagon Link to comment Share on other sites More sharing options...
BigJack Posted January 24, 2007 Share Posted January 24, 2007 I read a thread about the rallitek but it turned out it was for Impreza? Link to comment Share on other sites More sharing options...
4S-TURBO Posted January 27, 2007 Share Posted January 27, 2007 Rallitek rules! Sean is the nicest guy and has been helping me and my friends since back in the d'zay. I didn't get a GT on purpose, so I don't feel bad about having a 'slow' car. This thing is def faster and smoother than my 00GT, 01L, or 03SE. And I had some turbo cars in there, too Oh, yeah, and to the original post - I'm fitting the Tein Basic COs this month so I'll let everyone know how I feel about them...I had them on my 03SE wagon and loved 'em. Link to comment Share on other sites More sharing options...
