Struts worn out should i replace mounts too?
harman.khinda
Hi first post in a long time. Feels good to be back. :)
I'm working on my sisters 2009 Legacy it's NA. The car has ~85K miles everything is stock and struts feel like they are worn out (taking dips feels the front tire comes up a into the wheel well and going over speed bumps the rear comes crashing down). I know I need to replace the sturts is there anything else I should look into replacing? I've done one suspension swap on a 05 LGT but I'm wondering if there are other components (bushings?, tophats?, mounts?) i might need to replace.
Thanks a lot!
I replaced all my top hat's at 165,000 miles but really didn't need to, in my 05. I think you should be fine re-using them.
Engine Build - Click Here
