bluesuby Posted July 31, 2012 Share Posted July 31, 2012 I checked the Stant website for a part number and they show the same part number for the cap on the radiator and what they call "top of engine" which I believe is the tank on the right side (over the turbo). The OEM caps appear to be different, one having little "ears" and they other being perfectly round. Anyone know if the replacements are indeed the same part? Link to comment Share on other sites More sharing options...
bluesuby Posted August 1, 2012 Author Share Posted August 1, 2012 bump for an answer? Link to comment Share on other sites More sharing options...
Th3Franz Posted August 1, 2012 Share Posted August 1, 2012 which web site? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
bluesuby Posted August 2, 2012 Author Share Posted August 2, 2012 which web site? Stant. Their website includes an applications table which isn't so good as far as explaining about the second cap. What throws me is the different appearance of the oem caps. Link to comment Share on other sites More sharing options...
bluesuby Posted August 2, 2012 Author Share Posted August 2, 2012 I was checking my oil level and found another difference between the caps. They have different pressure ratings. I'm guessing you would want the lower pressure on the radiator cap so it'll open and vent into the overflow tank. No purpose in having the other cap vent because of the mess. Which leads me to believe Stant is just being lazy designating the same cap for both applications. Maybe I'll just go to a dealership and get the OEM replacements. Link to comment Share on other sites More sharing options...
Th3Franz Posted August 2, 2012 Share Posted August 2, 2012 yeah I have read about issues from using some cheap aftermarket caps. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2012 Share Posted August 6, 2012 I was checking my oil level and found another difference between the caps. They have different pressure ratings. I'm guessing you would want the lower pressure on the radiator cap so it'll open and vent into the overflow tank. No purpose in having the other cap vent because of the mess. Which leads me to believe Stant is just being lazy designating the same cap for both applications. Maybe I'll just go to a dealership and get the OEM replacements. Maybe I'll just go to a dealership and get the OEM replacements. I think you answered your own question. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rubberman Posted August 29, 2012 Share Posted August 29, 2012 I checked into this with the guys at Fred Bean's about 1.5-2 yrs ago. They determined that Subaru was now spec'ing the same rad cap for both the radiator & the tank by the turbo. It didn't make any sense to me that Subaru would originally spec two different caps based on the different pressure ratings and then go back on that later. I tried to look up the part numbers on the opposedforces.com website but I can't get it to load this morning. Link to comment Share on other sites More sharing options...
LatentWagen Posted August 29, 2014 Share Posted August 29, 2014 Bump from the dead. Trying to sort out my own 108 vs 137kpa mystery Anyone know if Subaru is still making round (no ears) 137kpa caps? LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Max Capacity Posted August 29, 2014 Share Posted August 29, 2014 I believe you can not put the cap on the wrong tank, they are different. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LatentWagen Posted August 29, 2014 Share Posted August 29, 2014 Not so sure about that. Fred Beans is specifying the same part number for both caps. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
AZP Installs Posted August 31, 2014 Share Posted August 31, 2014 OEM Rad caps and OEM Tstats we have found to work the best... -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted March 10, 2015 Share Posted March 10, 2015 Bump from the dead. Trying to sort out my own 108 vs 137kpa mystery Anyone know if Subaru is still making round (no ears) 137kpa caps I just payed a visit to the dealer today to pick up a replacement cap for my fill tank, which sits beside the turbo. The OEM replacement for the fill tank cap is now a 108kpa radiator-style cap which they said supercedes the original 137kpa spec. The parts guy had a spare round 137kpa cap with no ears, I believe for an STI, and was $28 instead of $8. An interesting note, I've been reading around and it seems that many of the LGT and OBXT guys have the 108kpa 'eared' cap installed onto the fill tank and the 137kpa on the radiator. Can anyone who's car is in good order verify if this is right? I've been having coolant overflow issues and after much pain a quick cap swap to the aforementioned configuration seems to have fixed it thus far. OBXT Link to comment Share on other sites More sharing options...
Brady Posted March 10, 2015 Share Posted March 10, 2015 I sadly replaced my radiator about a year ago because the cap on the radiator tested "good" at the lower rating as the reservoir on top of the motor. Yes, the cap on top of the Radiator is the 137 kpa, the cap on the reservoir is 108 (or whatever). Works out to be a 20psi cap on the radiator and 16 psi on the reservoir. Damn radiator cap tested good to 16 psi, replaced the radiator, still spewed fluid everywhere. Another parts store told me it should have been good to 20 psi. Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted March 10, 2015 Share Posted March 10, 2015 Thanks for the confirmation Brady. The cooling system on these cars seems to be very delicately balanced. Hopefully it stands the test of time. Link to comment Share on other sites More sharing options...
ilover Posted March 17, 2015 Share Posted March 17, 2015 OEM Rad caps and OEM Tstats we have found to work the best... -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" I would agree with this... Unless you are looking for performance parts... Link to comment Share on other sites More sharing options...
AZP Installs Posted March 17, 2015 Share Posted March 17, 2015 I would agree with this... Unless you are looking for performance parts... Hmm, except that the "performance" T-stats all fail (Trust us we've been doing this for a while) and the same goes for most if not all of the rad caps... -mike Link to comment Share on other sites More sharing options...
ilover Posted March 18, 2015 Share Posted March 18, 2015 Thanks for the correction AZP Installs! Cheers.... Link to comment Share on other sites More sharing options...
Fasemelta Posted December 29, 2015 Share Posted December 29, 2015 Reviving this one to help clarify if folks are still looking. Per Subaru's site: Upper reservoir cap - 45137AE00B Radiator cap - 45137FE002 Link to comment Share on other sites More sharing options...
