Aluminum Suspension Weight Savings
CapnJack
For those interested in what changing out to a Spec B aluminum suspension setup saves in weight, see below. I don't expect it to be much and don't expect much improvement, but I got the parts cheap and needed new bushings anyway.
Front A-arms - Approx 3 lbs savings per arm
Rear trailing arm - Approx 6.5 lbs per arm
Rear lateral links - Approx 1.5 lbs savings per link
Total savings of approximately 22 lbs.
Still think it's worth it? :spin:
I measured less difference in the LCA, but the others look similar.
Okay, here it goes:
20202AG160 - Front RH Control Arm - Bought from Legacy_Otaku, used with AVO bushings ($237.50)
20202AG170 - Front LH Control Arm - Bought from Legacy_Otaku, used with AVO bushings ($237.50)
20252AG021 - Rear RH Trailing Arm - Bought from K.O.P. ($296.17)
20252AG031 - Rear LH Trailing Arm - Bought from K.O.P. ($287.55)
For reference:
20250AG030 - Rear RH Upper Lateral Link - Bought from K.O.P. ($57.75)
20250AG040 - Rear LH Upper Lateral Link - Bought from K.O.P. ($57.75)
4BoxParts Adjustable "Forward" Lateral Links - ($175)
Differences:
Front Control Arms:
Steel 7.5lbs - Stamped and Welded Construction
Aluminum 6.5lbs - Cast/Forged Construction
Rear Trailing Arms:
Steel 17.8lbs - Cast Construction
Aluminum 11.2lbs - Cast/Forged Construction
Upper Lateral Links:
Steel 4.9lbs - Cast Construction
Aluminum 3.3lbs - Cast Construction
Rear "Forward" Links:
Not yet measured.
I've done this and you can certainly tell it's different.
Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs.
Don't control arms count as unsprung weight which would make a significant difference in handling? Same effect as lighter wheels, less weight moving up and down so responsiveness increases, only thing is right quality might suffer a bit.
Their mass is not entirely sprung or unsprung since they are attached to the chassis. Use 1/2 for approximation sake.
I agree with fahr - they make a noticeable improvement (more nimble and more comfortable), although I would argue if they are worth it at retail price. If you can get a clean used set for a good price then it becomes easier to justify.
I'm curious now how it will feel. I'm wondering if the bushings I'm replacing will make the biggest difference.
It's going to be a while though. This car has been in salt for half its life and I am having to replace knuckles from rusted bolts and I might as well replace the bearings, tie rod ends, and balljoints while I'm in there.
I had installed Powerflex bushings into my old steel arms before coming across the alloy ones used. I didn't like the Powerflex bushings so I installed GrpN bushings into the alloy which are a little more compliant. For sure the ride quality got better but I can't say if that is the weight difference or the bushings. What I can tell you is that I had to back the damping on my Konis off a little to compensate for the decreased weight.
