carguyco Posted February 18, 2010 Share Posted February 18, 2010 Okay today while driving kiddo #1 to school....I heard a beep...a little lighter beep than the beep when you move from S to S# or I on the SI drive knob....couldn't locate it and it didn't do it again... Tonight while driving kiddo #2 to volleyball it did it again, only this time I gazed in the right direction at the right time... My odo readout had changed to Outside temperature only...never even seen that display...I have a temp display but it has ET underneath it..this time the outside temp display was larger... And it magically switched itself back within seconds to my TripB fuel mileage and current fuel mileage display which I generally keep it on. HTF did that happen? Forgive me for not walking out into the 20 degree weather and 3 inches of snow to retrieve the owner's manual....I'd rather see if anyone else experienced that. I have had the car almost 2 weeks and it has only done that today... Anyone? Link to comment Share on other sites More sharing options...
kinder Posted February 18, 2010 Share Posted February 18, 2010 My guess is that the temp outside had just dropped or is hovering around freezing point. Once the temp hit freezing it beeps to warn you the roads may be icy. It does it to me everyday that its below 3deg celsius when I leave my garage. Link to comment Share on other sites More sharing options...
carguyco Posted February 18, 2010 Author Share Posted February 18, 2010 Aha! That is probably it....didn't realize this car did that...the wifes Yukon does it too... The reason I haven't noticed it before is because it was always below 20 the last week or so and never got above 20.... Hmm...I need to download my memory and figure out if that is it.. However...it was 37 degrees when it did it Link to comment Share on other sites More sharing options...
BrooklynBoy Posted February 18, 2010 Share Posted February 18, 2010 There are two dfferent spontaneous warnings from the odo readout......one when the cars thermometer reaches 37 degrees....and the other when the car has been running for 2 hours.(To remind us to take a rest !). Do it right the first time.........or don't bother doing it at all. Link to comment Share on other sites More sharing options...
carguyco Posted February 18, 2010 Author Share Posted February 18, 2010 There are two dfferent spontaneous warnings from the odo readout......one when the cars thermometer reaches 37 degrees....and the other when the car has been running for 2 hours.(To remind us to take a rest !). I guess I should have braved the snow to look at my manual...because now I remember that...thank you! Today must have been the first time I was driving in 37 degree weather in the last 2 weeks...and I did it twice! Link to comment Share on other sites More sharing options...
Windy Road Posted February 18, 2010 Share Posted February 18, 2010 There are two dfferent spontaneous warnings from the odo readout......one when the cars thermometer reaches 37 degrees....and the other when the car has been running for 2 hours.(To remind us to take a rest !). I get the temp one every once in a while when the temp goes down from say 40 to 37 it beeps. Now I've driven my car for two hours before and never had a beep saying to take a rest at the two hour mark. Friday I'll be driving up to the mountains which is about 2 hours away and I'll have to see if it beeps then, maybe with a constant 2 hour drive it will beep. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
rouar Posted February 18, 2010 Share Posted February 18, 2010 The "2-hour beep" will also beep at every hour thereafter. I got it to 4 hours straight driving one day before I arrived at my destination and had to turn off the car. Link to comment Share on other sites More sharing options...
Strizzy Posted February 18, 2010 Share Posted February 18, 2010 it was 37 degrees when it did it That's when it beeps. Same with mine too My bad luck build Link to comment Share on other sites More sharing options...
kinder Posted February 18, 2010 Share Posted February 18, 2010 Mine doesn't beep after 2 hrs of driving... :/ Link to comment Share on other sites More sharing options...
B-Power-B Posted February 19, 2010 Share Posted February 19, 2010 Yeah, I have never heard the 2 hr beep either. Only driven it once for that long...maybe I missed it Link to comment Share on other sites More sharing options...
B-Power-B Posted February 19, 2010 Share Posted February 19, 2010 Oh...and does it matter if you continue driving? Is it best to pull over and let her chill out for a minute? Link to comment Share on other sites More sharing options...
BrooklynBoy Posted February 19, 2010 Share Posted February 19, 2010 Yeah, I have never heard the 2 hr beep either. Only driven it once for that long...maybe I missed it You probably missed it.....after the beep,the screen changes to say something like :....E/T 2:00....and it's just a reminder for people to be aware that two hours have alteady passed----not a mechanical requirement to stop. If you pull over to get gas and shut off the car ; the timer resets. I think its a nice feature for older drivers ! Do it right the first time.........or don't bother doing it at all. Link to comment Share on other sites More sharing options...
landark Posted February 19, 2010 Share Posted February 19, 2010 Whew, glad I stumbled upon this. I was about to start tearing the car apart trying to figure this out. Link to comment Share on other sites More sharing options...
ajh5 Posted February 19, 2010 Share Posted February 19, 2010 This has been posted before, it beeps at 37 to alert you to the possibility of ice on the roads. Link to comment Share on other sites More sharing options...
RJS5689 Posted February 19, 2010 Share Posted February 19, 2010 The "2-hour beep" will also beep at every hour thereafter. I got it to 4 hours straight driving one day before I arrived at my destination and had to turn off the car. Yep, same here.... except I needed gas. Link to comment Share on other sites More sharing options...
