Scotty Posted September 15, 2007 Share Posted September 15, 2007 I did do a search, most of them are clunking noise when going over bumps. Mine makes a clunk, but never when going over bumps. Sometimes it makes a clunk, was on the left, now on the right, when I get on the brakes and then again when I get off the brakes. It only occurs at slower speeds right before you come to a stop, doesn't do it when slowing from higher speeds. Could it be the sway bar bushings? Link to comment Share on other sites More sharing options...
Legacy05 Posted September 15, 2007 Share Posted September 15, 2007 Possible, what about the h-brace? Did you check those bolts? Link to comment Share on other sites More sharing options...
andrew.anderson Posted September 15, 2007 Share Posted September 15, 2007 Scotty, What not stock suspension parts do you have on your car? Link to comment Share on other sites More sharing options...
BigBad Posted September 15, 2007 Share Posted September 15, 2007 A subtle clunk that occurs at slower speeds would be front sway bar bushings assuming your suspension is stock. Same thing happened to me earlier on in the life of my car. Brought it to the dealer, they replaced the bushings, re-greased and the problem was solved. Link to comment Share on other sites More sharing options...
Scotty Posted September 15, 2007 Author Share Posted September 15, 2007 All stock. Checked suspension and brake bolts, all tight. Didn't check the H brace. Link to comment Share on other sites More sharing options...
andrew.anderson Posted September 15, 2007 Share Posted September 15, 2007 I have no idea what the noise is. I wish you luck. Link to comment Share on other sites More sharing options...
rkl303 Posted September 15, 2007 Share Posted September 15, 2007 Was the H-Brace for me. Link to comment Share on other sites More sharing options...
Scotty Posted September 15, 2007 Author Share Posted September 15, 2007 H-Brace is tight. Link to comment Share on other sites More sharing options...
acooper5 Posted September 18, 2007 Share Posted September 18, 2007 i have it with my cobb sways but only when it is cold.... Semper Fi. Link to comment Share on other sites More sharing options...
Scotty Posted September 18, 2007 Author Share Posted September 18, 2007 Squirted some grease into the bushing, that seems to eliminated most of it. It doesn't do it as often. Link to comment Share on other sites More sharing options...
Bear Posted September 18, 2007 Share Posted September 18, 2007 Squirt more. Link to comment Share on other sites More sharing options...
LibertyGT Posted September 18, 2007 Share Posted September 18, 2007 Maybe get some poly bushes and install them, they wont wear out so easily. Tim Link to comment Share on other sites More sharing options...
DrGrip Posted September 18, 2007 Share Posted September 18, 2007 My front driver side creaks and makes noise when turning the wheel at low speeds... Link to comment Share on other sites More sharing options...
GTTuner Posted September 18, 2007 Share Posted September 18, 2007 Squirt more. :lol: You sound like on of my techs in my shop! Fill out an application please! BACK ON TOPIC; Sway bar clunks are easily to diagnose. Go to a quiet area that has substancial bumps. Drive over a bump and just let ONE wheel hit. If your noise is worse when only one tire hits a bump it IS most likely the bar-to-body bushings. I am very aggressive driving on and off ramps. My car eat's up the RF bushing every 15K or so. Good luck. Link to comment Share on other sites More sharing options...
Scotty Posted September 18, 2007 Author Share Posted September 18, 2007 Squirt more. I did before seeing your post. I do have 81K miles on this car and tend to be hard getting on the circular on ramps. So I suppose the bushings could be worn. It doesn't knock going over bumps. The only time it does it is after being in stop and go driving for a while, it'll have a faint knock when you first get on the brake and a louder one when you ease up on the brake right before you come to a complete stop. It is intermitten and I can't get it to do it every time. Link to comment Share on other sites More sharing options...
BigBad Posted September 20, 2007 Share Posted September 20, 2007 Its the bushings. Replace them, easy fix. Link to comment Share on other sites More sharing options...
