don7 Posted April 30, 2014 Share Posted April 30, 2014 I have tried everything to get rid of the toughest water spots on my windows. I have tried no less than 3 compounds specifically made for the job, steel wool, you name it... In desperation i was rooting around my kitchen and i came across some brass cleaner and i remember it smelling strongly of ammonia last time i used it so i gave it a shot. Son of a bitch if that stuff didn't rip those fuckers off that glass like they weren't even there!! I accelerated the process even more with the aid of some #0000 steel wool and it works great. I used Wrights brass cleaner and i think i got it a Winco or something. Don't get it on the paint or tint because it will probably do awful things. Always do a test area first, not responsible for damage ect ect.... Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 30, 2014 Share Posted April 30, 2014 Now, silly question but did you try Windex first? I think it has ammonia in it too. Link to comment Share on other sites More sharing options...
bluesuby Posted April 30, 2014 Share Posted April 30, 2014 Griot's Garage (based in Washington State) makes a clay for glass which works like a clay bar for paint. In fact, it's probably the same stuff. Link to comment Share on other sites More sharing options...
Brady Posted April 30, 2014 Share Posted April 30, 2014 If the water spots are etched, the ammonia isn't what helped here, it was the abrasives in the brass cleaner (polish). And there are different formulations of Windex, some have ammonia, some do not. Often vinegar will clean up water spots as well, but not likely etched marks. Link to comment Share on other sites More sharing options...
don7 Posted May 1, 2014 Author Share Posted May 1, 2014 I dont know what it was because i have used much more abrasive products on it and it didn't do shit, so it could be a mixture of things. Either way, if you need it, it definitely makes your life easier. Link to comment Share on other sites More sharing options...
Diggerdan11 Posted May 2, 2014 Share Posted May 2, 2014 Metal polish and 000 steel wool works miracles! Link to comment Share on other sites More sharing options...
quick4dr Posted May 2, 2014 Share Posted May 2, 2014 Chemical guys makes an awesome water spot remover. Also the glass can be wetsanded with 3000-3500 disks. Soft hands and patience. Link to comment Share on other sites More sharing options...
Wang Lung Posted May 4, 2014 Share Posted May 4, 2014 Good info, thanks. Link to comment Share on other sites More sharing options...
capttris Posted May 12, 2014 Share Posted May 12, 2014 Vinegar has done wonders for me! Just wet a paper towel with it and wipe slowly and let it soak into the glass. I have ONLY used on glass, not plastic or anything painted. Link to comment Share on other sites More sharing options...
mhoran89 Posted May 13, 2014 Share Posted May 13, 2014 Vinegar is great at removing mineral deposits on tons of stuff (including glass). An aggressive clay can help as well. When I worked at a detailing shop we would burn through tons of #0000 steel wool. It is a major asset to have when encountering windows in rough shape; also works well in conjunction with a razor blade to get glue off after removing window tint. If the spots are still there after all that, I would resort to polishing the glass. There are plenty of companies that make specialized glass polish but you can usually use whatever you might have; don't be afraid to put pressure, glass is much harder than clear coat. Link to comment Share on other sites More sharing options...
