GCGC Posted October 28, 2013 Share Posted October 28, 2013 Hi all So i've decided to change the door-step light bulb to LEDs. Can someone who has done this before please help me out? The manual says 'Remove the lens by prying the edge of the lens with a flat-head screwdriver.' Well, that sounded easy, but i am seriously not having much luck. I don't want to apply too much pressure because i am worry that i might break something (again!) Any help or advice would be much appreciated. Link to comment Share on other sites More sharing options...
krot84 Posted October 28, 2013 Share Posted October 28, 2013 It's not much of a deal. Just use a little flat screw driver on the small latch you can see on the light cover. Don't worry you won't brake it. Link to comment Share on other sites More sharing options...
GCGC Posted October 28, 2013 Author Share Posted October 28, 2013 Thanks Krot84 Like you said, i used a small screw driver (the one used for repairing watches etc), and success! Looking at the 4 latches, i don't think that i would be doing this often. Now i run into another problem. I found that the light is consistently on when the door is open. I tried flicking the interior light off, but unfortunately that doesn't turn off the door light? So i have two options; 1. Replace the bulb when the door is close, or 2. Replace the bulb when the bulb is lit I am guessing option one is the best bet? Link to comment Share on other sites More sharing options...
krot84 Posted October 28, 2013 Share Posted October 28, 2013 I don't know how option one is even possible.. I used option two, it's a matter of seconds after you remove the cover and replace the bulb. I used these lights for the doors - they're perfect http://www.ebay.com/itm/281152627719?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 Link to comment Share on other sites More sharing options...
