zedhead Posted May 20, 2013 Share Posted May 20, 2013 Is there a larger oil filter available for the EJ25DE? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 21, 2013 Share Posted May 21, 2013 . . . why. . . . ? Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 21, 2013 Share Posted May 21, 2013 No need, wix or oem, done. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 22, 2013 Share Posted May 22, 2013 Nothing specifically.. All 4 cylinder EJ Subaru's actually use the same exact oil filter all the way up to the STi Any oil filter that is the same diameter as the "designated" filter will fit, you'll just have to find one that is longer as well. I don't really know what advantages or disadvantages there are to using a larger filter. Link to comment Share on other sites More sharing options...
InsertEnigmaHere Posted May 22, 2013 Share Posted May 22, 2013 Driveworks filters are a good inch larger in diameter than the Mobil 1 filter I ordinarily use. The gasket lines right up but the body of it is oversized Link to comment Share on other sites More sharing options...
Zues Marine Posted May 22, 2013 Share Posted May 22, 2013 . . . why. . . . ? Link to comment Share on other sites More sharing options...
Fake Outback Posted May 24, 2013 Share Posted May 24, 2013 First post, so hello awesome forum! Anyway, I believe there is. A while back I ordered one that was significantly longer (than the usual shorty you get at the auto parts store) from autohausaz.com. The brand was Bosch. Lemme see if I can find it... Yep, here it is! http://imgur.com/lC16T6d Hope that helps! Link to comment Share on other sites More sharing options...
pleaidestar Posted May 24, 2013 Share Posted May 24, 2013 ?????......???? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted May 24, 2013 Share Posted May 24, 2013 I once got a much larger diameter filter. I bought it at AutoZone I believe. Go to your local auto parts store and look at the different brands. Some might be larger. This one was at LEAST an inch wider. I think maybe even more. Link to comment Share on other sites More sharing options...
ehsnils Posted May 24, 2013 Share Posted May 24, 2013 A larger filter has in theory larger filter area, but it's not necessarily true - it also depends on how many times the filter material is folded and then the quality of the filter material also plays a role. But if you take two filters of the same brand but with different physical size it's likely that the larger filter has a larger filter area. Search on the net and you will see that there's a large variations in filters, and if you want to experiment with different filters you need to consider the threading and diameter of the connection, the diameter of the outer seal and also that the outer diameter isn't too large since then it will get in contact with the headers - and that's not good. A longer filter of the same diameter as the original and with the same mounting towards the engine would work. But personally I would go for a magnetic oil plug instead of hunting for a larger filter. Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 24, 2013 Share Posted May 24, 2013 Yes to magnetic and id stay away from bosch filters. Link to comment Share on other sites More sharing options...
Fake Outback Posted May 24, 2013 Share Posted May 24, 2013 Yes to magnetic and id stay away from bosch filters. How come? From what I've read they are better than something like Fram or some other run of the mill filter. I stick to Mobil now myself.. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 24, 2013 Share Posted May 24, 2013 There's nothing wrong with Bosch oil filters. Personally, I will either use a Mobil1 or OEM filter. Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 25, 2013 Share Posted May 25, 2013 Every bosch filter I've gotten has had a pitiful job of chasing the threads on inlet and the rubber o ring, in one case with my civic, was all wonkey and didn't seal from just hand tightening. It pissed oil as soon as I started it. I guess if you have had good luck with them keep on, I just never have. Link to comment Share on other sites More sharing options...
pleaidestar Posted May 25, 2013 Share Posted May 25, 2013 I don't like organic media, the wix filters and mobil1 filters use a synthetic mesh that doesn't breakdown. Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 25, 2013 Share Posted May 25, 2013 That too^ Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted May 27, 2013 Share Posted May 27, 2013 I always use the Subaru blues & have never had an issue. For a box of 3 or so, I pay about $25, which isn't bad. I also have a powerful magnetic oil drain & a small, 8lbs magnet under the oil filter itself. I can go up to 7000mi on the same oil & it will STILL be amber by the time it needs to be changed. Link to comment Share on other sites More sharing options...
subikid90 Posted May 27, 2013 Share Posted May 27, 2013 Wix filter is the only filter I will ever use. It is larger than the oem filter by quite a bit. Get them on rockauto for ~$60 for a case of 12. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
zedhead Posted May 28, 2013 Author Share Posted May 28, 2013 Why, You ask? Because with 280K miles, the engine is using some oil. I'm sure the rings are worn, and some oil is getting by. It's not smoking, but extended (2+Hrs)freeway runs usually mean a quart of oil lost. Sometimes a little more. A larger oil filter would hold more than the oem 1.5 pints. Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 28, 2013 Share Posted May 28, 2013 But more filtration wont make it use less oil.. If anything I would use 3.2 quarts of rotella 5w40 and replace a full quart of oil with a quart of lucas oil stabilizer (full synthetic). It got rid of lifter tick I had for a while until I got around to adjusting the lash. Link to comment Share on other sites More sharing options...
zedhead Posted May 28, 2013 Author Share Posted May 28, 2013 I'm not looking for more filter media. I'm looking for more oil capacity Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 29, 2013 Share Posted May 29, 2013 You'd get much more oil capacity by installing an oil cooler than you would out of a larger filter Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 29, 2013 Share Posted May 29, 2013 I was gonna say an oil cooler is about as easy as an actual engine mod you can do besides doing intake/ignition things. That would give you at least a quart, even more depending on line diameter, how many rows the core is etc... Link to comment Share on other sites More sharing options...
zedhead Posted May 30, 2013 Author Share Posted May 30, 2013 I'm really not interested in putting an oil cooler on a 300k mile engine. I am interested in putting a little larger capacity oil filter on it. So, does anyone know if there is a larger oil filter that works with the EJ25D? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 30, 2013 Share Posted May 30, 2013 Wix filter is the only filter I will ever use. It is larger than the oem filter by quite a bit. Get them on rockauto for ~$60 for a case of 12. Link to comment Share on other sites More sharing options...
