c-lo Posted October 28, 2010 Share Posted October 28, 2010 think my front rotors are slightly warped. I've done the bedding in procedure twice now...seem a bit better but still get a slight steering wheel wobble at 60. my wheels have been rotated and are balanced, so not related. front right passenger side pad is starting to scrape, so it's probably time to replace. question: I forgot how to check if rotors need to be replaced. This is my second or third set of rotors I've put on (155k on the car). should I just replace my front rotors and pads all around? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Alekss Posted October 29, 2010 Share Posted October 29, 2010 Well, if you drive at highway speeds and feel shaking in your steering wheel under braking, then most likely its your rotors. You may machine them if you have enough thickness left. If you decide to go with the new rotors, then get the new pads as well. Link to comment Share on other sites More sharing options...
