ryanlucas13 Posted July 24, 2012 Share Posted July 24, 2012 Hello, I had a fog light out, so I bought a H3 replacement bulb to put in it. I swapped the old with the new, but it still doesn't work. I thought maybe the bulb was bad, so I got another one and have the same issue. Are there separate fuses for each light?? I looked in the fuse panel, but only saw 1 that said Fog Lights. Has anyone had an issue with their fog lights? The driver side works, but the passenger one does not. I am not sure what else it could be.....thanks for any answers. Link to comment Share on other sites More sharing options...
shadowsports Posted July 24, 2012 Share Posted July 24, 2012 Corrosion is unlikely but possible. You sure it was fully seated/connected? I would think you could test output with an ohms meter. Link to comment Share on other sites More sharing options...
bluesuby Posted July 24, 2012 Share Posted July 24, 2012 Make sure the grounding wire has not been pulled off. Very aggravating set-up considering the limited space for getting your hands in there to do the work. Link to comment Share on other sites More sharing options...
ryanlucas13 Posted August 4, 2012 Author Share Posted August 4, 2012 Where does the ground wire attach too? I just want to make sure I didn't unhook that. Link to comment Share on other sites More sharing options...
-Samurai- Posted August 4, 2012 Share Posted August 4, 2012 There should be one wire actually attached to the fog light "cap" on the rear, and the actual connector that plugs into your bulb. And the metal clip that hold the bulb there HAS to be secured because it is part of the ground. Link to comment Share on other sites More sharing options...
