MikeCA1974 Posted August 17, 2008 Share Posted August 17, 2008 Hey All, Can you tell me the best location (or locations) for me to tap into these sources? I'm installing an Eclipse Nav system and the Subaru manual wasn't particularly clear on where these were located: Speed signal Battery Power Acc Power Reverse Signal Thanks! ----Mike Link to comment Share on other sites More sharing options...
Makster Posted December 27, 2012 Share Posted December 27, 2012 I need this information also....speically the speed pulse? Link to comment Share on other sites More sharing options...
nstg8r Posted December 27, 2012 Share Posted December 27, 2012 It's going to depend on which year/trim model you have. Link to comment Share on other sites More sharing options...
AkumaMax Posted December 27, 2012 Share Posted December 27, 2012 It's going to depend on which year/trim model you have. yep! I know you can grab the battery and ACC from the radio harness. As for the reverse signal you need to get that from the passengers footwell area it's a BROWN with YELLOW STRIPE wire. As for VDC that needs to be taken from the rear of the Gauge Cluster it's the 22pin green connector to the driver side of the rear of the cluster. That wire is GREEN WITH A BLACK STRIPE it's pin 19! Link to comment Share on other sites More sharing options...
Makster Posted December 28, 2012 Share Posted December 28, 2012 Oops ...mine is 98 legacy outback Link to comment Share on other sites More sharing options...
