MoffatRodney Posted January 23, 2010 Share Posted January 23, 2010 So I'm buying a set of 2006 STi front calipers from a guy on NASIOC, and have ordered a set of DBA 4000 rotors for a 2004 STi from Fred Beans Parts. I also ordered the Goodridge stainless steel lines while I was at it - do the Legacy GT Stainless Steel lines couple to Brembos without a problem? I was going to order the STi Stainless Steel lines, but the guy at Fred Beans said I would definitely want the Legacy ones, even if I was going to Brembos. Anyone got any experience? Link to comment Share on other sites More sharing options...
integroid Posted January 23, 2010 Share Posted January 23, 2010 You need to order the kit for the Legacy GT. The fronts are the same between a Legacy and STi...The rears are completely different so you would need the Legacy kit. Link to comment Share on other sites More sharing options...
Squiden Posted January 23, 2010 Share Posted January 23, 2010 Yep, I completely agree with integroid. The rear GT SS lines will mate to the Brembos, but you must have the GT lines (it's actually 2 lines in the rear, versus a single on the WRX and STI). Link to comment Share on other sites More sharing options...
atc5 Posted January 23, 2010 Share Posted January 23, 2010 there is a vendor on here (magnetic1?) that sells the correct fitment lines for the rears. Link to comment Share on other sites More sharing options...
FredBeans Posted January 24, 2010 Share Posted January 24, 2010 So I'm buying a set of 2006 STi front calipers from a guy on NASIOC, and have ordered a set of DBA 4000 rotors for a 2004 STi from Fred Beans Parts. I also ordered the Goodridge stainless steel lines while I was at it - do the Legacy GT Stainless Steel lines couple to Brembos without a problem? I was going to order the STi Stainless Steel lines, but the guy at Fred Beans said I would definitely want the Legacy ones, even if I was going to Brembos. Anyone got any experience? I advised you to the Legacy GT Kit on the live chat the other day. Did you think I was steering you the wrong direction? Just kidding sir We have performed this swap in our shop a few times, thats why I suggested the Legacy Brake Line kit with confidence -Jeremy Link to comment Share on other sites More sharing options...
magnetic1 Posted January 24, 2010 Share Posted January 24, 2010 there is a vendor on here (magnetic1?) that sells the correct fitment lines for the rears. The LGT ones work too. The custom ones we make are just a little shorter. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
MoffatRodney Posted January 24, 2010 Author Share Posted January 24, 2010 I advised you to the Legacy GT Kit on the live chat the other day. Did you think I was steering you the wrong direction? Just kidding sir We have performed this swap in our shop a few times, thats why I suggested the Legacy Brake Line kit with confidence -Jeremy Yeah, I didn't doubt you Jeremy - just as a technician, I always double check my info before I do anything Saves lots of headaches that way! I've ordered the lines and some DBA4000's from you. Link to comment Share on other sites More sharing options...
ktmrider Posted January 27, 2010 Share Posted January 27, 2010 So I'm buying a set of 2006 STi front calipers from a guy on NASIOC, and have ordered a set of DBA 4000 rotors for a 2004 STi from Fred Beans Parts. I also ordered the Goodridge stainless steel lines while I was at it - do the Legacy GT Stainless Steel lines couple to Brembos without a problem? I was going to order the STi Stainless Steel lines, but the guy at Fred Beans said I would definitely want the Legacy ones, even if I was going to Brembos. Anyone got any experience?I just got some front Brembos ( also on Nabisco ) that included some STI GR SS lines. While swapping in my Bilsteins I compared the STI lines to my stock LGT ones. Length is the same, banjo and hardline is same. Only diiference I could see was the line to strut mounting tab, STI uses a flex clip vs the LGT bolt-in. No info on the rears however that's been covered already... Link to comment Share on other sites More sharing options...
