quick4dr Posted January 28, 2012 Share Posted January 28, 2012 What speakers size are the fronts and rear on the Legacy? I will be running JL throughout are spacers required? Any help appreciated! Link to comment Share on other sites More sharing options...
Drift Motion Posted January 28, 2012 Share Posted January 28, 2012 it's 6.5 in up front dont know the rear...go to crutchfield and you can find out Link to comment Share on other sites More sharing options...
quick4dr Posted January 29, 2012 Author Share Posted January 29, 2012 Are spacers mandatory for front? Link to comment Share on other sites More sharing options...
Drift Motion Posted January 29, 2012 Share Posted January 29, 2012 most people say you need one to clear the windows...i just use the bracket that came with my speakers... Link to comment Share on other sites More sharing options...
itsme Posted January 29, 2012 Share Posted January 29, 2012 I have 6.5 front and rear. I had to use spacers only in the front. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
bomberlegacy Posted January 29, 2012 Share Posted January 29, 2012 You have less than 2" depth without spacers up front. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
quick4dr Posted January 29, 2012 Author Share Posted January 29, 2012 anyone have the link to the member who sells the spacers? Link to comment Share on other sites More sharing options...
itsme Posted January 29, 2012 Share Posted January 29, 2012 I just used the standard spacers you can find anywhere like best buy, local radio shop, etc.... Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
2000_LegacyOutback Posted February 5, 2012 Share Posted February 5, 2012 In my doors i had to use JL TR-600 instead of the TR-650, The 6.5 inch speakers didnt fit in either door without spacers Link to comment Share on other sites More sharing options...
phenryiv1 Posted February 14, 2012 Share Posted February 14, 2012 anyone have the link to the member who sells the spacers? Sorry that I missed this thread. It is me. Follow the links below. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
ericgu Posted February 15, 2012 Share Posted February 15, 2012 You definitely need spacers. I've put JL 6.5 C2s and C3s in (2005 gt, 2007 outback). If you are very handy you can mod the existing speakers into spacers, but you are probably better off buying the spacers. Link to comment Share on other sites More sharing options...
phenryiv1 Posted February 15, 2012 Share Posted February 15, 2012 You definitely need spacers. I've put JL 6.5 C2s and C3s in (2005 gt, 2007 outback). If you are very handy you can mod the existing speakers into spacers, but you are probably better off buying the spacers. I don't think that the OEM speakers have a large enough basket to work with those JL models, which require a mounting diameter that is larger than the cone size of the oem speakers. OEM cone = 5" JL mounting diameter = 5.5" and 5.625" Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
ericgu Posted February 16, 2012 Share Posted February 16, 2012 I don't think that the OEM speakers have a large enough basket to work with those JL models, which require a mounting diameter that is larger than the cone size of the oem speakers. OEM cone = 5" JL mounting diameter = 5.5" and 5.625" Yeah, it's not terribly straightforward, but you can do it. Pictures here. But, as I said, I think buying spacers is a better idea. I didn't know about them on the GT and then was antsy on the outback. I should also have mentioned that if you want to use the JL components and put the tweeters in the original location, the C2 tweeters drop right into the stock mounts (held in with some hot glue), but you will have to modify the mounts to hold the C3 tweeters. Link to comment Share on other sites More sharing options...
phenryiv1 Posted February 16, 2012 Share Posted February 16, 2012 Yeah, it's not terribly straightforward, but you can do it. Pictures here. But, as I said, I think buying spacers is a better idea. I didn't know about them on the GT and then was antsy on the outback. I should also have mentioned that if you want to use the JL components and put the tweeters in the original location, the C2 tweeters drop right into the stock mounts (held in with some hot glue), but you will have to modify the mounts to hold the C3 tweeters. Not bad work. If your DIY method fails, feel free to drop me a line. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
