08 Spec.B w/Swift Wagon Springs: Spacers too?
Max Q
Is everyone generally happy with the taller rear wagon springs on the sedan or are we using saggy butt spacers with those too? If so, which size?
Also to clarify, swifts front sedan and wagon springs are the same part and it's just the rears that are different?
I've got sedan swifts on my 08 specB sedan. The back does sag a little but I don't mind it that much. You shouldn't need spacers if you're using the wagon springs on the sedan.
The saggy butt spacers are usually 3/4" -1" thickness I think. 3/4" are used more often from what I've seen.
Yes swift fronts are identical, wagon and sedan rears are different.
  • 1 month later...
