levis76 Posted February 13, 2009 Share Posted February 13, 2009 Found this online a bit ago. It has some good info. If you have an auto with problems, give it a read.http://www.subaru-faq.ru/pdf/transmission/4eat.pdf Link to comment Share on other sites More sharing options...
cman7 Posted February 13, 2009 Share Posted February 13, 2009 Thanks for the link. After reading it looks like I need another solenoid. The garage that worked on my car and replaced the diff replaced one of them. I just don't know which one it is. It had to do with torque binding so I'm going to guess Duty C. I think I need an A. When replacing a solenoid, do you need to disassemble the transmission? Would that include draining/refilling fluid? Link to comment Share on other sites More sharing options...
old legacy GT Posted February 16, 2009 Share Posted February 16, 2009 Awsome link man thanx!!!! Link to comment Share on other sites More sharing options...
levis76 Posted February 17, 2009 Author Share Posted February 17, 2009 When replacing a solenoid, do you need to disassemble the transmission? Would that include draining/refilling fluid? You will definitely have to drain the fluid. The solenoid is on the valve body, which drops down through the pan opening. Pulling the VB isn't too bad from what I have seen, but I don't know if would be opening that thing up. It's a mess inside. Link to comment Share on other sites More sharing options...
jonklein611 Posted February 17, 2009 Share Posted February 17, 2009 You will definitely have to drain the fluid. The solenoid is on the valve body, which drops down through the pan opening. Pulling the VB isn't too bad from what I have seen, but I don't know if would be opening that thing up. It's a mess inside. I think that's one area for the stealership to mess with. I had my speed sensor go, they had to drop the pan and split the trans to replace the harness. $200 in parts, $900 labor. Not cheap, but worth it for it to be done right. Got new gaskets and fluid out of it too. Trans is out of my comfort zone, I guess it depends on how wrench capable you are, and how much time you have... Link to comment Share on other sites More sharing options...
