dspurgin22 Posted July 14, 2013 Share Posted July 14, 2013 Long story short I installed my coilovers today and found tucked under my seat, a bunch of what looks like sub and amp wires. Im new to the aftermarket stereo stuff, so would be awesome if someone could tell me what ive got going on here. Can I wire a sub? A sub and an amp?? Thanks!! Link to comment Share on other sites More sharing options...
Scubaru03 Posted July 14, 2013 Share Posted July 14, 2013 Thats what it looks like. Mine has a factory sub under the driver seat. I have never actually looked at the wires though. So not sure if thats factory wiring i doubt it. Link to comment Share on other sites More sharing options...
grovlet Posted July 14, 2013 Share Posted July 14, 2013 That's definitely not factory wiring.... Factory will never use crimp on connections. Looks like one end of RCAs, Speaker Wire, and probably a remote turn on wire (crimp connection). Now what are they connected to on the other end? At least where are they under the dash? You would have to find that out before you can use them. You would also need Power/Ground wires for an amp as well. Link to comment Share on other sites More sharing options...
dspurgin22 Posted July 14, 2013 Author Share Posted July 14, 2013 I found a big red power wire connected to the battery, and there is a black ground wire that didnt make it into the picture. Other than that I havent done to much digging into the dash but I also was told about needing a fuse really close to the battery? So i guess that will be the next thing to find. Thanks for the help!! Link to comment Share on other sites More sharing options...
ssbtech Posted July 14, 2013 Share Posted July 14, 2013 Don't try to use someone else's crappy wiring job. If you want to do something, pull the existing wires out and reinstall. You never know if someone's gone and extended a power wire using a big ball of electrical tape as the connection method Link to comment Share on other sites More sharing options...
Chicken Freak Posted July 19, 2013 Share Posted July 19, 2013 i wouldnt trust old wiring. my advice is start over. check out sonic electonix.com i purchace quite abit from them. look up amp wiring kits, perferably a 4 gauge kit. Link to comment Share on other sites More sharing options...
dspurgin22 Posted July 20, 2013 Author Share Posted July 20, 2013 Ill look into it for sure, appreciate the help guys! Link to comment Share on other sites More sharing options...
