bofronado Posted October 18, 2015 Share Posted October 18, 2015 I was hoping I was done after the engine! I have just the driver's window that goes down. The others will not respond from the driver's door switch or on the other doors. Where do I start? Link to comment Share on other sites More sharing options...
NewLegGT67 Posted October 18, 2015 Share Posted October 18, 2015 Make sure the button that prevents the other windows to go down is not pressed. It's a safety feature so young children or your dog cannot control the windows. It's on the driver's window panel where the window controls are. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
bofronado Posted October 19, 2015 Author Share Posted October 19, 2015 Make sure the button that prevents the other windows to go down is not pressed. It's a safety feature so young children or your dog cannot control the windows. It's on the driver's window panel where the window controls are. I can only get the driver's side window to roll down. All the others will not roll down from either the driver's main control or from the individual door controls. The window lock shouldn't lock out the master control on the driver's door, right? Although the lock button is pretty loose, and does not have a positive click into position. Link to comment Share on other sites More sharing options...
1692 Posted October 25, 2015 Share Posted October 25, 2015 I can only get the driver's side window to roll down. All the others will not roll down from either the driver's main control or from the individual door controls. The window lock shouldn't lock out the master control on the driver's door, right? Although the lock button is pretty loose, and does not have a positive click into position. It's been a while since I had my 96, but I was pretty sure that the master control locked out all controls, and I couldn't roll the windows up or down at all when activated using any of the controls. Just a guess, but it sounds like your lock switch is bad. Mine was a pretty firm click when it was activated or deactivated. That was one of the few items that I could always find pretty readily at my local pull and pay junkyard. I wouldn't recommend eBay or anything like that since you can't inspect the switches first and may end up with the same issue, or worse. Link to comment Share on other sites More sharing options...
David E Posted March 19, 2017 Share Posted March 19, 2017 My drivers side power window is acting up - not always working when the switch is pressed. What are the odds it is switch only? What all years / models will fit as replacement? Can I just swap over the "wood" trim? Link to comment Share on other sites More sharing options...
twisty Posted March 20, 2017 Share Posted March 20, 2017 95 to 99 should all work, and yes if you take the time you can swap over the trim as well. id pull yours and give it a good clean before i replaced it tho, they get dirty and gummed up. Link to comment Share on other sites More sharing options...
