1-3-2-4 Posted February 9, 2015 Share Posted February 9, 2015 I want to clear the codes to see if the front left is a fluke I already know about the two white plugs but I saw nothing in any of the discussions about how to clear the codes. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2015 Share Posted February 9, 2015 turn the car on/off 4 times, that will reset and codes that are not serious. Pull the negative battery cable and step on the brake a few times also works or leave the cable off for about 15 minutes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 9, 2015 Share Posted February 9, 2015 Only downside is that the battery/brake trick will reset your ECU as well. So it'll have to relearn again. But I don't think it is a big deal really since I've seen that the ECU learns pretty fast anyway.. Link to comment Share on other sites More sharing options...
