boxkita Posted November 14, 2014 Share Posted November 14, 2014 Given the amount of time I've been on this forum, I'm somewhat ashamed to admit I've never done any engine work on my car. Whether I was lucky or had lots of bucks to pay someone else is not relevant. Times have changed and I can no longer "outsource" my engine work. So bring it... With that out of the way, my stage 4 wagon started blowing white smoke after a dozen or so hard slalom runs back in May. I limped it home. Then took it to my shop of choice for a second opinion. They agreed that the HGs were on the way out (little black floaties in the upper coolant tank), as well as the radiator being toast. Me, being somewhat paranoid and desiring to avoid more drama, parked it and bought another car. Now, many months later, after, in a moment of weakness, confessing to Mrs Boxkita that I was trying to find a sponsor who would be willing to finance the conversion of said wagon into a racecar; I can choose to sleep in the car or I can sell it. As the days of sleeping in my car still do not bring good memories, I need to fix it and sell it. As noted above, a change in finances means I'm doing this job in my garage with my tools and likely borrowed tools and hopefully some more experience help. Given my tendency to incur drama with this car, feel free to comment/suggest/heckle as you see fit. I'll try to share my adventures with pictures and words. Although I do have a deadline, so at some point, I may get frustrated and part it out. So... Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 Call this the "getting ready to work on car" post. With the first part being clean up the garage so I can pull a car in. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 Parts list: Crank Seal: 806733030 Intake Cam Seal: 806742160 Exhaust Cam Seal: 806732160 Intake Cam Bolt: 13199AA000 Exhaust Cam Bolt: 13199AA010 Master Gasket kit: PN 10105AA720 Cam Gear Bolts: http://turninconcepts.com/tic-fu-cam-bolt-kit-single-avcs.html Crank Pulley list: http://legacygt.com/forums/showthread.php/crank-pulley-list-price-weight-part-s-221509.html FluidDamper - http://www.fluidampr.com/ Crawford AOS v2 GB - http://forums.nasioc.com/forums/showthread.php?t=2683500 PW T-Bolts - http://legacygt.com/forums/showpost.php?p=4123347&postcount=3117 FuijBond/HondaBond - http://legacygt.com/forums/showpost.php?p=5318790&postcount=136 Tools list: 8mm-17mm, plus 22mm, 24mm deep, plus extensions & wobbly u-joint. 6mm 6-point 1/4 inch or 3/8 inch socket for the oil covers on the cam sprockets 14mm 12pt for the head bolts 17mm & 19mm open end wrench for the Company23 Cam Tool 1 22mm 6-point 1/2 inch for the crank pulley bolt 36mm wheel bearing socket for setting the cam seals with rubber mallet 5/16inch 12point socket for arp studs nut T-25 Torx screwdriver for the fuel injector screws. TorxPlus TP50 for flywheel nuts? O2 sensor socket set of metric hex bits so I can pull the pressure plate a breaker bar rubber mallet What to buy threads: MrTris rebuild list - http://legacygt.com/forums/showthread.php/engine-rebuild-shopping-list-226719.html How to threads: MrTris build thread - http://legacygt.com/forums/showthread.php/tris-build-thread-223568.html Max Capacity build thread - http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html Rebuild Head (JmP) - http://legacygt.com/forums/showpost.php?p=4812508&postcount=121 Rebuld head (YT) - Replace Crank Pulley - http://legacygt.com/forums/showthread.php/install-lightweight-crank-pulley-224447.html Remove Cam Bolts (TL) - http://legacygt.com/forums/showpost.php?p=4800753&postcount=74 Company23 CamTool usage - http://www.company23.com/download/Subaru%20Camlock%20Manual.pdf Company23 Cam Sprocket tool usage - http://www.company23.com/download/Subaru%20Cam%20Sprocket%20Tool%20Manual.pdf Replace Crank Cam Seals - http://legacygt.com/forums/showthread.php/replace-crank-cam-seals-222936.html Replace Timing Belt - http://legacygt.com/forums/showthread.php/timing-belt-replacement-2-5t-106809.html Replace Timing Belt (Video) - http://legacygt.com/forums/showthread.php/video-timing-belt-replacement-2-5t-229365.html Remove Banjo Bolt screens - http://legacygt.com/forums/showthread.php/remove-all-banjo-filters-222758.html HammerDown's version - http://legacygt.com/forums/showpost.php?p=4769949&postcount=2 Replace PW TMIC - http://legacygt.com/forums/showthread.php/processwest-intercooler-install-lgt-fitment-170515.html CovertRussian's rebuild thread - http://legacygt.com/forums/showthread.php/covertrussians-05-lgt-build-thread-218363.html Replace 2.8 LGT ratio with 2.4 STI - http://legacygt.com/forums/showthread.php/underdog-motorsports-2015-sti-steering-rack-swap-234351.html Replace PS o-ring - http://legacygt.com/forums/showthread.php/power-steering-o-ring-fix-197481.html FLuidDamper testing - http://www.motoiq.com/MagazineArticles/ID/2829/PageID/5561/Project-GD-STI--Improving-the-Fuel-System-with-Injector-Dynamics-and-Other-Details.aspx OEM Gasket set - http://www.scoobymods.com/showthread.php/4th-gen-legacy-gt-engine-14437.html?t=14437 Starter Motor rebuild - http://www.scoobymods.com/showthread.php/diy-walk-through-ej2-x-14407.html?t=14407 Side Feed Injector R&R - http://www.scoobymods.com/showthread.php/4th-gen-legacy-2005-2006-14328.html?t=14328 Fuel Pump Control Module Wiring Upgrade - http://www.scoobymods.com/showthread.php/diy-4th-gen-legacy-gt-14434.html?t=14434 ....Original thread - http://legacygt.com/forums/showthread.php/upgrading-your-fuel-pump-wiring-4th-gen-213570.html?highlight=FPCM+WIRING Power Steering Pump Fluid Upgrade - http://www.scoobymods.com/showthread.php/diy-4th-gen-legacy-power-14640.html?t=14640 Fuel & Vacuum Line routing - http://legacygt.com/forums/attachment.php?attachmentid=167975&d=1384657978 Turbo stud solution - http://legacygt.com/forums/showthread.php/no-more-stripped-turbo-tmic-threads-75715.html Before Startup: http://legacygt.com/forums/showthread.php/diy-oil-system-priming-tank-214760.html Shops: Witch hunter Performance (for injector testing) - http://legacygt.com/forums/showpost.php?p=4803599&postcount=87 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 Ordered List: Purchased List: [ame=http://www.amazon.com/Grimmspeed-Phenolic-Thermal-Spacer-3mm/dp/B0054RGIKU/]3mm Phenolic Spacers[/ame] - delivered [ame=http://www.amazon.com/gp/product/B000CMF20O/]Mr Gasket 738G: [/ame] - delivered cam gear bolts! $40 from TurnIn Concepts - borrowed from BMB until mine ship Mishimoto X-Line radiator - delivered Mishimoto hose kit (black) - delivered OEM Subaru master gasket set - delivered (6) cans of CRC brake cleaner - delivered (still owe MrTris) (2) Blackstone oil analysis kits - delivered (still owe MrTris) Infamous VenAir hoses (all 3 options) - delivered Gates Racing TB Component Kit from Infamous AEM DryFlow Panel Filter from Infamous OEM Crank Pulley (2) p/s pump o-rings (3) OEM oil filters & gasket (need to return these) PCV valve (3) "black" oil filters & gasket - http://pages.ebay.com/link/?nav=item...d=181356739512 Hose kit from FreeRange Racing - delivered (2) Napa "true black" RTV sealant/gasket maker. Had to buy a new one after destroying the first one with vise grips 07 Topfeed TGV, unmodified SpecB front LCA, rear trailing arms, and upper rear arm 07 STI v25b heads - http://legacygt.com/forums/showpost.php?p=5177101&postcount=1 - 2007 sti v25b heads (unicorn heads ) with supertech springs, titanium retainers, inconel std size exhaust valves, std size intake valves, and stock cams. Cams were just polished, journals all line honed and polished a month ago, comes with all new cam cap bolts. The driver side head will need some new valves due to the timing belt tensioner failure. Nasioc post on the heads - http://forums.nasioc.com/forums/showthread.php?t=1471829 GTSpec EL headers w/welded slip joints - http://legacygt.com/forums/showpost.php?p=5177101&postcount=1 Headlights w/5k HID installed - http://legacygt.com/forums/showpost.php?p=5177101&postcount=1 Headlights w/HID installed - by MrTris Stock Y-pipe with muffler deletes welded on - http://legacygt.com/forums/showthread.php/wa-catback-straight-pipes-stock-249310.html Company23 TB guide Company23 Valve Spring Compressor 2 OEM HG - cause you need 2 not 1. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 Parts/Tools on loan: Company23 cam wrenches - Boxman Crank Pulley Wrench - Boxman Crane Leveler - Boxman Crane & engine stand - MrTris Tools returned: Cam Bolts from TiC - BMB Company23 cam wrenches + overnight shipping - BMB Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 Before Startup: Underdog's pre-oiling rig for 1st startup - http://legacygt.com/forums/showthrea...nk-214760.html Underdog's startup checklist - http://legacygt.com/forums/showpost.php?p=5127735&postcount=519 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 part 6 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 Part 7 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 14, 2014 Moderators Share Posted November 14, 2014 Part 8 "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
MrTris Posted November 14, 2014 Share Posted November 14, 2014 Can't wait for this to happen! It's gonna be glorious. You'll finally be one of the cool kids! Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 14, 2014 Moderators Share Posted November 14, 2014 John, FWIW, I don't think this is anything you can't handle with write ups that are here and else where. Pull the motor (easy enough, just some time), remove heads, have a shop R&R 'em, slap it back together. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 you know how many threads I've seen where that simple process goes awry? Now add in my special blend of Drama. I'm going to move all the hammers to a friend's place miles away. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
MrTris Posted November 14, 2014 Share Posted November 14, 2014 Dude, the hardest part will be setting the valves and timing. I think it'll be just fine. Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 So, I'm driving home thinking about taking the car apart. Pretty soon, I'm thinking of what else I could do, too. By the time I got home, I'd ported/polished the heads, added ELH, racing radiator, Infamous hose kit, Crawford AOS, custom single outlet exhaust, put on the aero bits, and thinking about caging it. Then I remembered why I was doing my own engine work. G'damn lotto. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 14, 2014 Moderators Share Posted November 14, 2014 So, I'm driving home thinking about taking the car apart. Pretty soon, I'm thinking of what else I could do, too. By the time I got home, I'd ported/polished the heads, added ELH, racing radiator, Infamous hose kit, Crawford AOS, custom single outlet exhaust, put on the aero bits, and thinking about caging it. Then I remembered why I was doing my own engine work. G'damn lotto. You have a problem Now pull your motor, g'dammit! Don't buy anything, just pull it and disassemble. Then figure out what you NEED to reassemble and buy those bits. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 Seems to me, that's how I ended up in the spot. This weekend is set aside for clearing a space in the garage to get the car inside. MrTris has an engine hoist & stand to loan, so need to get that picked up. Then I can pull it in Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2014 Share Posted November 14, 2014 You have read my thread haven't you...? only take apart what you have to. See my click here link...you should have seen it by now...your not new here. The three of us can give you all the help you need. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Gex Posted November 14, 2014 Share Posted November 14, 2014 I would be more then happy to help with the motor R&R after the thanksgiving holiday. Just let me know! Link to comment Share on other sites More sharing options...
keenster Posted November 14, 2014 Share Posted November 14, 2014 You guys anywhere near Ohio? Haha. I have beer.... Lots of beer. And a machine shop we can screw around with! wink wink Link to comment Share on other sites More sharing options...
boxkita Posted November 14, 2014 Author Share Posted November 14, 2014 You guys anywhere near Ohio? Haha. I have beer.... Lots of beer. And a machine shop we can screw around with! wink wink I wish. Based in Seattle Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
SBT Posted November 15, 2014 Share Posted November 15, 2014 You have a problem Now pull your motor, g'dammit! Don't buy anything, just pull it and disassemble. Then figure out what you NEED to reassemble and buy those bits. Kettle meet Pot... - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Chris GTO TT Posted November 15, 2014 Share Posted November 15, 2014 In for the shens.... 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
magnusonsubie Posted November 15, 2014 Share Posted November 15, 2014 In for possible and inevitable future need to do myself. I have the same problem of thinking about all I want to do. I sketched out an priced a $20,000 fully closed deck engine build with all forged internals, larger cams, and all kinds of other stuff that would just end up causing damage to the car itself. Good luck with the HG repair. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
boxkita Posted November 15, 2014 Author Share Posted November 15, 2014 Honestly 20k seems light for what you want to do Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 15, 2014 Share Posted November 15, 2014 You guys anywhere near Ohio? Haha. I have beer.... Lots of beer. And a machine shop we can screw around with! wink wink JmP6889928<not too far from Ohio...LOL.. Link to comment Share on other sites More sharing options...
