galpdawg Posted January 10, 2012 Share Posted January 10, 2012 looking to get winter tires for my rims. they are 18x7 2006 spec b rims. I am running 225 40 18 on my one set of rims. But for winter what is a good size. 215 40 18 or 215 45 18? Link to comment Share on other sites More sharing options...
Learjet45 Posted January 10, 2012 Share Posted January 10, 2012 Might be worth looking at this: http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html Also, be aware that changing the tire size from stock will change the rolling diameter and thus your speedometer will be off by a certain percentage and your odometer will also be off. If this doesn't bother you, than well I really have nothing else helpful to add in terms of a good size. Just wanted to make sure you know. Link to comment Share on other sites More sharing options...
galpdawg Posted January 10, 2012 Author Share Posted January 10, 2012 Yeah i was looking at that, but for some reason i thought the stock tire size for the 2006 spec b was 215 45 18. yeah i want to make sure i keep the rolling diameter as accurate as possible. Link to comment Share on other sites More sharing options...
galpdawg Posted January 10, 2012 Author Share Posted January 10, 2012 found this https://www.subaru.com/content/downloads/pdf/brochures/2006_Specb.pdf it shows stock size of 215 45 18. so is it best to run this in winter or 225 40 18? thanks for the help Link to comment Share on other sites More sharing options...
Learjet45 Posted January 10, 2012 Share Posted January 10, 2012 Is your LGT a SpecB, or are you just rolling on specb wheels? I know my 2.5i is 205/50r17, which the closest rolling diameter in 18" is 225/40r18. I'm not sure on any of the stock tire sizes for the different trim levels, someone else will have to speak up on that part. Link to comment Share on other sites More sharing options...
galpdawg Posted January 10, 2012 Author Share Posted January 10, 2012 no i just have spec b rims. Link to comment Share on other sites More sharing options...
