Heedz Posted January 24, 2012 Share Posted January 24, 2012 http://img196.imageshack.us/img196/6074/39585527546249383741040.jpg http://img838.imageshack.us/img838/8077/40708227546263384091040.jpg I see that the AVO re-enforcement is available but does that tear need to be welded? Can anyone with this experience chime in? Link to comment Share on other sites More sharing options...
CapnJack Posted January 24, 2012 Share Posted January 24, 2012 The AVO kit is going to help, but something needs to be done with the crack. My suggestion would be to weld the subframe to the new AVO piece and use it a a re-enforcement backer piece. Link to comment Share on other sites More sharing options...
jhawk222 Posted January 24, 2012 Share Posted January 24, 2012 What anti-sway is that in the photo above? Link to comment Share on other sites More sharing options...
Subie5 Posted January 24, 2012 Share Posted January 24, 2012 The AVO kit is going to help, but something needs to be done with the crack. My suggestion would be to weld the subframe to the new AVO piece and use it a a re-enforcement backer piece. +1 ^^ This is the route I would go. Not only does it add the additional support but it will help with the sway you have pictured also. Have the tear welded at the same time Link to comment Share on other sites More sharing options...
whitetiger Posted January 24, 2012 Share Posted January 24, 2012 for the first picture, you will need to weld and then use the avo brackets. for the second pic, buy energy suspension rear sway bar bushings. they come with a new "c" brackets which are much stronger than the stock garbage and only about $30 a set IIRC Link to comment Share on other sites More sharing options...
Heedz Posted January 24, 2012 Author Share Posted January 24, 2012 What anti-sway is that in the photo above? Perrin adjustable 22mm at medium stiffness Link to comment Share on other sites More sharing options...
whitetiger Posted January 24, 2012 Share Posted January 24, 2012 here http://www.energysuspensionparts.com/proddetail.asp?prod=9.5108 Link to comment Share on other sites More sharing options...
Heedz Posted January 24, 2012 Author Share Posted January 24, 2012 Thank you whitetiger, I was looking around and was wondering if it was just universal or not, I guess those will be on order soon. WPmarky was suggesting the same via facebook to me too. Link to comment Share on other sites More sharing options...
mazdaslo Posted January 25, 2012 Share Posted January 25, 2012 how did you discover the damage, visual inspection during maintenance, or was it terrible noises, or something amiss with the handling? Link to comment Share on other sites More sharing options...
Code Posted January 25, 2012 Share Posted January 25, 2012 here http://www.energysuspensionparts.com/proddetail.asp?prod=9.5108 Is there a reason that you suggest non greasable? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
whitetiger Posted January 25, 2012 Share Posted January 25, 2012 i like the larger bracket. Link to comment Share on other sites More sharing options...
chutrain Posted January 25, 2012 Share Posted January 25, 2012 I have the greaseable version and they work fine. I used the grease fitting once already, and a lot better than having to take the bracket off to grease the bushings. Link to comment Share on other sites More sharing options...
jhawk222 Posted January 25, 2012 Share Posted January 25, 2012 Waiting for spring to hit the NE before I install my bars and brackets. Link to comment Share on other sites More sharing options...
Heedz Posted January 29, 2012 Author Share Posted January 29, 2012 Okay Planning on ordering these, Part Number: 9.5158 will that fit both my front and rear? My sway bars are both 22mm but I know the bracket shaping is different any experience here? Link to comment Share on other sites More sharing options...
tito_b0y Posted January 29, 2012 Share Posted January 29, 2012 Okay Planning on ordering these, Part Number: 9.5158 will that fit both my front and rear? My sway bars are both 22mm but I know the bracket shaping is different any experience here? Yes, the 9.5158 will fit 22mm bars. You will have to trim the brackets for the front. http://legacygt.com/forums/showthread.php/energy-suspension-bushings-review-install-cusco-97981.html?t=97981&highlight=energy+suspension+sway+bar+bushings+front 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
Heedz Posted January 29, 2012 Author Share Posted January 29, 2012 ^Ahhh thanks appreciate it!!! Link to comment Share on other sites More sharing options...
jhawk222 Posted February 4, 2012 Share Posted February 4, 2012 Waiting for spring to hit the NE before I install my bars and brackets. I mispoke.......better yet LIED!!!!! Installed bars, bushings, endlinks and rear bracket yesterday!!!:lol: Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 5, 2012 Share Posted February 5, 2012 how did you discover the damage, visual inspection during maintenance, or was it terrible noises, or something amiss with the handling? +1 Link to comment Share on other sites More sharing options...
Code Posted February 5, 2012 Share Posted February 5, 2012 Your bar will bang around if a mount breaks. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 5, 2012 Share Posted February 5, 2012 Your bar will bang around if a mount breaks. I think the handling would be poor as well especially when hitting bumps and taking turns. I drove a Toyota Prado last year which had a broken endlink. The car was so scary to drive when I was hitting a bump or driving on uneven road. Felt like chassis was going one way and frame another. Link to comment Share on other sites More sharing options...
