Chrisbl Posted May 21, 2010 Share Posted May 21, 2010 Hi everyone.. My little audio-build is almost finished, but I have some details that I'm not especially satisfied with. I chose to put my amplifier under the passenger seat instead of in the trunk, and the amp fits in nicely. However, I'm having trouble figuring how to securely mount the amp. As of now, its just lieing there and I'm not sure thats a good idea once its connected to the battery. Does anyone have any suggestions on how to mount this without having to drill new holes into the car? Link to comment Share on other sites More sharing options...
clarkwgriswold Posted May 21, 2010 Share Posted May 21, 2010 If you really don't want to put holes in the carpet, to keep it from sliding try velcro. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 21, 2010 Share Posted May 21, 2010 mine just sits underthe seat, unattached. Never has moved cept when people kick it My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
biz77 Posted May 21, 2010 Share Posted May 21, 2010 1. Remove seat. 2. Remove trim along front and rear door sill as well as lower B-pillar trim panel. 3. Fold carpet back. 4. Cut 1/2" ply or MFD board slightly larger than amplifier foot print. 5. Apply liquid nails (it doesn't take much) to underside of wood and place on bare floor and let setup for a couple of hours. 6. Fold carpet back over board and secure amp to board, making sure screws are just long enough to not penetrate THROUGH the board. 7. Reassemble. Small holes in carpet will never be visible if/when amp is removed and board under carpet will be undetectable. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 21, 2010 Share Posted May 21, 2010 or do what I did. Run wires to under seat. Attach to amp. Slide under seat. Forget about it. There aren't many amps that are thin enough to fit under the seat. Adding 1/2" of anything isn't gonna make it easier My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
rice_rocket Posted May 22, 2010 Share Posted May 22, 2010 Yeah.. leave it, seriously, how much acceleration do you think you have to actually move that amp when it's hooked up to wires? I had 3 amps at my disposal when I did my install, and none of them fit, so I had no choice but to put it in the trunk. I'd just throw it in and call it a day, velcro if anything. Link to comment Share on other sites More sharing options...
darkside Posted May 22, 2010 Share Posted May 22, 2010 If your amp has screw holes you could always use some zipties, cut small incision on carpet and put zipties thru carpet then to amp or velco if it will stick. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 22, 2010 Share Posted May 22, 2010 Hook side of velcro on bottom of amp will keep i from sliding around My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Chrisbl Posted May 23, 2010 Author Share Posted May 23, 2010 I just left it there. Figured its a waste of time trying to mount it anyway. It's too wide to slide around and even if I crash it would probably not be able to fly away from where its sitting.. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 24, 2010 Share Posted May 24, 2010 If you crash, it will bounce around under the seat, probably only receiving cosmetic damage. It would have to get through the seat and break free of all it's wires to hurt someone. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
