MAP Posted May 30, 2014 Share Posted May 30, 2014 Thought it would be a good way to see if there are any trends related to engine/turbo failure and model year. For those that have had either failure, what model year is your GT? Link to comment Share on other sites More sharing options...
JermTheElf Posted May 30, 2014 Share Posted May 30, 2014 2005-2006 due to banjo bolt oil feed filter. Link to comment Share on other sites More sharing options...
Nrw Posted May 30, 2014 Share Posted May 30, 2014 05 due to age 08 due to rod bearing changes Link to comment Share on other sites More sharing options...
WhiteMonster06 Posted May 30, 2014 Share Posted May 30, 2014 06 vf40 exhaust housing seal cracked and leaked oil into exhaust, major shaft play... at 93k though, so i guess it lasted a long ass time! Link to comment Share on other sites More sharing options...
tLewis7 Posted May 31, 2014 Share Posted May 31, 2014 09 spun rod bearing @ 18K Link to comment Share on other sites More sharing options...
MAP Posted May 31, 2014 Author Share Posted May 31, 2014 I should have made 10 categories... Model year w/failure for each model year and Model year w/no failures for each model year. That way everyone on this forum could cast a vote and we could get a very good picture/sample size. There's been almost 200 views and only a few votes cast for failures. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 1, 2014 Share Posted June 1, 2014 Mine was turbo bearings wearing out on my 05, at 142,000 miles. Caught it before it put metal into the oil system. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bjrongo Posted June 1, 2014 Share Posted June 1, 2014 My 05 LGT Wagon turbo failure @106k Sent from my HTCONE using Tapatalk Link to comment Share on other sites More sharing options...
freaksavior Posted June 1, 2014 Share Posted June 1, 2014 115k turbo went out, lots of shaft play. Link to comment Share on other sites More sharing options...
Merc6 Posted June 4, 2014 Share Posted June 4, 2014 05 fell into the turbo eats engine loop. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
chato Posted June 4, 2014 Share Posted June 4, 2014 i wish this poll had an option for model year without blown engine as a control. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 4, 2014 Share Posted June 4, 2014 i wish this poll had an option for model year without blown engine as a control. oh, that's easy, 2009. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
chato Posted June 4, 2014 Share Posted June 4, 2014 oh, that's easy, 2009. I meant as in an option for each model year, so we could get a control for how many people don't have blown engines and how many people are represented from each year as well. Link to comment Share on other sites More sharing options...
heiche Posted June 4, 2014 Share Posted June 4, 2014 Bought my 2005 a couple of years ago with a pre-blown turbo and possible engine damage. Tore it down all the way to the crank to make sure all was well, and luckily it was. Did a few upgrades during reassembly. It's been a great car ever since. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
MAP Posted June 5, 2014 Author Share Posted June 5, 2014 chato, see post #6 above... unfortunately that didn't occur to me until after I started it... But 22 responses out of 393 views is about 5% if you assume the rest that viewed the poll haven't had a problem... Link to comment Share on other sites More sharing options...
Merc6 Posted June 5, 2014 Share Posted June 5, 2014 chato, see post #6 above... unfortunately that didn't occur to me until after I started it... But 22 responses out of 393 views is about 5% if you assume the rest that viewed the poll haven't had a problem... This or they were smart enough to not brag about how their engine didn't blow. It was only a few months after I checked no for the VF 40 thread till mine blew. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
lee07 Posted June 6, 2014 Share Posted June 6, 2014 2005 but its also the first year model and the oldest at 10 years now. Made in 2004 Best looking though Link to comment Share on other sites More sharing options...
snm95ls Posted June 6, 2014 Share Posted June 6, 2014 You guys make me paranoid. Decided that I should start saving for a shortblock just in case. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 6, 2014 Share Posted June 6, 2014 ^ yep, smart move, that's what I did. see my click here link. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Merc6 Posted June 6, 2014 Share Posted June 6, 2014 Block and turbo, they seem to be the new item to change when you do timing belt. I hear this also makes the spark plug swap a breeze. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
heiche Posted June 6, 2014 Share Posted June 6, 2014 Block and turbo, they seem to be the new item to change when you do timing belt. I hear this also makes the spark plug swap a breeze. I may replace these items during every oil change going forward. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
__raj Posted June 6, 2014 Share Posted June 6, 2014 My turbo was pulled off during a valve job. At 167,000 miles it was deemed it excellent condition with barely any play. (3500 OCI dino oil changer). Its bolted back onto newly fixed motor. Fixed motor= valve job and new rings + pleathora random parts, gaskets for $3000. OEM Banjo bolt screens were pretty clean but replaced. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted June 6, 2014 Share Posted June 6, 2014 At 249k, waste gate move all the way to the right. Touching turbine housing wall. Shaft play is min. would still run turbo if waste gate wasn't hitting the wall. http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/0523141311_zps5cf4c281.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/0523141312_zps6b46d1b1.jpg Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
BMG905 Posted June 6, 2014 Share Posted June 6, 2014 How many owners who suffered failures had the banjo fitting and screen serviced at regular intervals? I'm not looking to blame those who didn't, but to see how important it is for long turbo and engine life. I have 115k on my LGT and have had the screen changed twice so far, the first at 60k and the second at about 100k. Link to comment Share on other sites More sharing options...
BMG905 Posted June 6, 2014 Share Posted June 6, 2014 Merc6 has a good point about the sparkplug swap, and changing coils is easier too. Link to comment Share on other sites More sharing options...
