RomanC Posted March 14, 2012 Share Posted March 14, 2012 I would like to replace the two turbo bolts that attach the TMIC to the turbo. Does anybody know the part number for those? Its a 12m bolt. Also, does anybody know where to buy the silver tabs that are on the vents (the centre piece). The one tab at the centre console vent on the passenger side vanished somehow, and it bugs me a bit. Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2012 Share Posted March 14, 2012 TMIC to turbo is 8mmx1.25 35 or 45 long, go to any hardware store and buy some. Also be careful not to over tighten them, the threads on the turbo are aluminum. If you strip them out just use a longer 6mm bolt and nut's and washers. The other part, just go to the vendor link at the top of the page and click on the dealer and go through the parts book. Or go to your local dealer 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
