Al Thomson Posted April 1, 2012 Share Posted April 1, 2012 Started getting mis-fires on Cyl #4 today. Wondering how many miles people got before loosing a coil pack? Link to comment Share on other sites More sharing options...
20lgt06 Posted April 1, 2012 Share Posted April 1, 2012 my cylinder 4 misfire was a burnt valve 2k job , check for loose connections and replace the plugs. but get a compression test / leak down before dropping money into anything. i have 100k miles stage 3 Link to comment Share on other sites More sharing options...
Al Thomson Posted April 1, 2012 Author Share Posted April 1, 2012 Ouch, I just did the plugs a few weeks ago. Cyl 4 is the one closest to the drivers seat, correct? Link to comment Share on other sites More sharing options...
compsurge Posted April 1, 2012 Share Posted April 1, 2012 1. Check to make sure it's seated properly first 2. Check plug for signs of cracking (it happened to me and finally threw a CEL) 3. Check plug gap 4. Swap coil pack with another cylinder and see if CEL follows it 5. Swap injector with another cylinder and see if CEL follows it 6. Compression and/or Leakdown Test Link to comment Share on other sites More sharing options...
VermontGT Posted April 1, 2012 Share Posted April 1, 2012 My cyl 4 misfire was a failed piston ring/land. Sell that shiznit while it still idles well. Link to comment Share on other sites More sharing options...
McKennaR Posted April 1, 2012 Share Posted April 1, 2012 What my tuner thought was a misfire due to a failed ringland & a cracked piston was really just a failed #1 coil pack causing a misfire. So heed these horror stories because they do happen, but don't start to worry until you've tried the easy stuff. For me, it was moving the offending coil pack to a different cylinder and having the misfire follow it around (what compsurge said) that led me to replace it. My 5MT car has 94,000 on it, Stage 2 for about 30k prior to my ownership, 3 of 4 original coil packs that I know of. The "new" one we put in was from a 122k OBXT. My 5eat car has 97k, original coil packs, bone stock. Link to comment Share on other sites More sharing options...
Al Thomson Posted April 1, 2012 Author Share Posted April 1, 2012 Yeah, that's what I am hoping for. Its just a pita to get in there and pull it. I think #4 is on drivers side nearest the firewall. Link to comment Share on other sites More sharing options...
McKennaR Posted April 2, 2012 Share Posted April 2, 2012 My apologies for the off-site image linking (and I snagged this from NASIOC). http://i5.photobucket.com/albums/y198/Goso/56f2343f.jpg Link to comment Share on other sites More sharing options...
Balrock Posted April 2, 2012 Share Posted April 2, 2012 My #4 was also a bad coil pack. It was cracked and moisturegot into it was causing the misfire. You can have a cracked ringland and still idle fine and make normal power. Your oil just likes to go bye bye. Link to comment Share on other sites More sharing options...
Al Thomson Posted April 8, 2012 Author Share Posted April 8, 2012 So 1-4 done per Compsurge suggested. I actually found that I had the -11 version of the one step colder plugs, so they were gapped wrong. Plugs replaced and new coil pack on #4, it ran great for about 10 miles then threw the CEL again. The roughness count is sometimes steady and at other times counts up like crazy. I guess injector next then pressure and leak test. Link to comment Share on other sites More sharing options...
compsurge Posted April 9, 2012 Share Posted April 9, 2012 Plugs looked good, otherwise? I had dropped my package from about 2 feet and apparently that was enough to cause one of my plugs to develop a crack in the porcelain. Swapped that plug out and problem solved. Yours sounds like it could be an injector. If one is bad, you can buy a new one or see if sending them for a cleaning will solve it. Depends if you have down time. Link to comment Share on other sites More sharing options...
Al Thomson Posted April 9, 2012 Author Share Posted April 9, 2012 Took it to the dealer today. Burnt valves! Looks like a strip down is on the cards. Link to comment Share on other sites More sharing options...
compsurge Posted April 9, 2012 Share Posted April 9, 2012 Nooooooo Link to comment Share on other sites More sharing options...
brawline Posted April 10, 2012 Share Posted April 10, 2012 Just replaced #4 coil pack today. 60k miles on it. I would just swap numb 2 and 4 and see if the code follows. Edit. Sorry didn't see your last post. Sent from my PC36100 using Tapatalk Link to comment Share on other sites More sharing options...
Diomedes88 Posted April 29, 2018 Share Posted April 29, 2018 Any else have a hard time to get the coil pack to seat correctly? I cannot for the life of me get coil #3 to seat1 Link to comment Share on other sites More sharing options...
Wasted Potential Posted April 30, 2018 Share Posted April 30, 2018 Look into the coil pack and make sure the female end is open an accepting. If not, pay her money and usually they are more open to new things. Link to comment Share on other sites More sharing options...
Diomedes88 Posted May 1, 2018 Share Posted May 1, 2018 I switched spark plugs, coil packs (both new and tire old one) and still have the same results. Again I'm not sure if it is a plug and coil problem or injector....ect. I've cleaned the MAFS. Its' still idling rough and code reads misfire cylinder #3. I guess the next step is swap the #3 injector and see if the code follows. Anyone have any other suggestions. I leaning towards doing a compression leak down test as well. Link to comment Share on other sites More sharing options...
