amp583 Posted December 12, 2013 Share Posted December 12, 2013 I have a bent air stem pin - the actual tiny ass pin that gets pressed when inflating. I haven't been successful in straightening it using pliers. Anyone ever fix one of these? Is the air stem separate than the TPMS? Link to comment Share on other sites More sharing options...
ras06LGT Posted December 12, 2013 Share Posted December 12, 2013 It's not part of the TPMS. Just replace it. The part you bent is the valve stem core and they are removable. You don't really want it to leak even if you can fix it. The replacement parts and tools to remove it are super cheap at any auto parts store. Obviously your tire will go flat when you removed it - how much depends on how fast you are in changing it. Link to comment Share on other sites More sharing options...
amp583 Posted December 13, 2013 Author Share Posted December 13, 2013 The good thing is, they're on a spare set of winter rims/tires that I'll be throwing on. Thanks! Link to comment Share on other sites More sharing options...
cseagle08 Posted December 13, 2013 Share Posted December 13, 2013 They even sell those replaceable stems at walmart. I think you need a specific tool that usually comes with some of them. Something like this: http://www.walmart.com/ip/Slime-4-Way-Valve-Tool/16879919 Link to comment Share on other sites More sharing options...
StoplightAssassin Posted December 13, 2013 Share Posted December 13, 2013 If you don't have the valve core removal tool, you can use two small allen keys. And if you ever need a valve core in a pinch, there's an extra one in your spare tire, just don't forget to replace it asap. Link to comment Share on other sites More sharing options...
