bobo69 Posted May 22, 2006 Share Posted May 22, 2006 is it possible or has anyone installed a STS on a legacy that has an STi STS from the factory? is there anything different? Link to comment Share on other sites More sharing options...
kanoswrx Posted May 22, 2006 Share Posted May 22, 2006 Theirs really not much point in changing it out for a different one unless you have driven another car that has an aftermarket one and really liked it that much more. I can't imagine the shifts being that much shorther. I'd just save the money for something that will help the car more like sway bars Link to comment Share on other sites More sharing options...
SC GT Posted May 22, 2006 Share Posted May 22, 2006 Yes. My LGT came with the STi STS. I wanted a shorter (as in lower) rod, so I installed the Kartboy. It fits perfectly. Some say that the shift linkage is the same between stock and the STi STS, and that the only difference between the two is the shift rod. I can't verify that as fact since I never had the stock one to compare against mine, but I can verify that the Kartboy does fit, and I like it better than when I just had the STi STS rod. Link to comment Share on other sites More sharing options...
bobo69 Posted May 22, 2006 Author Share Posted May 22, 2006 Yeah the only reason that i want to change it out for a lower gear selector i dont really need or like a 6ft. selector from a tractor Link to comment Share on other sites More sharing options...
