Alsalam4man Posted September 24, 2017 Share Posted September 24, 2017 When the pressure on the gasoline in the car does not give full performance ... Its performance is very weak and the electricity in the speed index is unstable, although there is an indicator of the engine on the screen sometimes. Are these faults all of the oxygen sensor Link to comment Share on other sites More sharing options...
xtea Posted September 24, 2017 Share Posted September 24, 2017 We have a bot! Link to comment Share on other sites More sharing options...
Max Capacity Posted September 24, 2017 Share Posted September 24, 2017 Does this mean there is a CEL ? "although there is an indicator of the engine on the screen sometimes" Just read the code, its that easy... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted September 24, 2017 Share Posted September 24, 2017 Alsalam4man = peace for mankind from Arabic, might give a clue. Maybe the writer does not have English as a first language? It sounds like he is getting poor performance when trying to accelerate and seeing the check engine light. As Max says, you need to find out what the trouble code or codes are. Then you can diagnose the problem. Find someone with an OBD2 reader and get the codes. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 24, 2017 Share Posted September 24, 2017 Yes, may be English isn't his first language. We're here to help... OP, Let us know where your from 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08spec.b. Posted September 24, 2017 Share Posted September 24, 2017 Yes, may be English isn't his first language. We're here to help... OP, Let us know where your from I speak Arabic fluently maybe I can help if needed. Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 Please i can't speak English very well .. Any one can speak with me Arabic language ? Thanks for all Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 Alsalam4man = peace for mankind from Arabic, might give a clue. Maybe the writer does not have English as a first language? [emoji38] It sounds like he is getting poor performance when trying to accelerate and seeing the check engine light. As Max says, you need to find out what the trouble code or codes are. Then you can diagnose the problem. Find someone with an OBD2 reader and get the codes.I am speak arabic .. and use Google Translate to speak with you ... Can any one help me ? Sorry ... if i did not speak english good[emoji17] تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 Does this mean there is a CEL ? "although there is an indicator of the engine on the screen sometimes" Just read the code, its that easy...trouble code is : P0030 .. yes .. i have Engine light ..!!! I need help ? تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 We have a bot!I am not a bot ..! Can u help me i have issue..?? My trouble Code is P0030 when i scan engine by OBDll with elm327 .. تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 Alsalam4man = peace for mankind from Arabic, might give a clue. Maybe the writer does not have English as a first language? [emoji38] It sounds like he is getting poor performance when trying to accelerate and seeing the check engine light. As Max says, you need to find out what the trouble code or codes are. Then you can diagnose the problem. Find someone with an OBD2 reader and get the codes.My trouble code is :: P0030 My car is :: Subaru legacy 2007 ((my pic profile)) تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 Yes, may be English isn't his first language. We're here to help... OP, Let us know where your fromI am from lebanon تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
solidxsnake Posted September 26, 2017 Share Posted September 26, 2017 Sounds like you have a front O2 sensor issue. Has it ever been replaced? Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 Sounds like you have a front O2 sensor issue. Has it ever been replaced?O2 sensor . Is that convert my performance engine to leak ?? Or low [emoji15] تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
solidxsnake Posted September 26, 2017 Share Posted September 26, 2017 A failing oxygen sensor can cause poor performance as the engine won't meter fuel correctly. Here's a video demonstrating how to replace it. It may be more telling to see what I'm talking about instead of trying to deal with the language barrier [ame=http://www.youtube.com/watch?v=B_eKbdsy-Os]How to replace your front O2 sensor on a WRX/STI - YouTube[/ame] Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 I have subaru legacy 2007 ... not impreza.!!! Is it same? No diffirent? ... and no different between impreza o2 sensor ...and legacy 2007 o2 sensor ? تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
solidxsnake Posted September 26, 2017 Share Posted September 26, 2017 I have subaru legacy 2007 ... not impreza.!!! Is it same? No diffirent? ... and no different between impreza o2 sensor ...and legacy 2007 o2 sensor ? تم الإرسال من SM-A9100 باستخدام Tapatalk Same procedure, but the part may be different. What engine is in the car? 2.5 liter? 2.5 liter with turbo? 3.6 liter? Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 Same procedure, but the part may be different. What engine is in the car? 2.5 liter? 2.5 liter with turbo? 3.6 liter?I have subaru legacy 2007 with (engine 2.0 liter) AWD without turbo ... 4 cylinder تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
MilesA Posted September 26, 2017 Share Posted September 26, 2017 I have subaru legacy 2007 ... not impreza.!!! Is it same? No diffirent? ... and no different between impreza o2 sensor ...and legacy 2007 o2 sensor ? It is a very similar procedure for Legacy. Do not buy a cheap replacement part, they do not work well. Get the genuine Denso part, probably Denso part number 192400-2120, but you should check at the auto parts store to make sure that is the correct part number for your car. Do not buy this part from the Subaru dealer unless you have no other choice. They can be very expensive from the Subaru dealer. Link to comment Share on other sites More sharing options...
solidxsnake Posted September 26, 2017 Share Posted September 26, 2017 In addition, the Subaru part number is likely 22641AA381 Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 It is a very similar procedure for Legacy. Do not buy a cheap replacement part, they do not work well. Get the genuine Denso part, probably Denso part number 192400-2120, but you should check at the auto parts store to make sure that is the correct part number for your car. Do not buy this part from the Subaru dealer unless you have no other choice. They can be very expensive from the Subaru dealer.Ok ... thanks for u alot ... Buy the o2 sensor type Denso ? تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
solidxsnake Posted September 26, 2017 Share Posted September 26, 2017 Ok ... thanks for u alot ... Buy the o2 sensor type Denso ? تم الإرسال من SM-A9100 باستخدام Tapatalk Yes, I wouldn't get anything besides the correct Denso part. Link to comment Share on other sites More sharing options...
MilesA Posted September 26, 2017 Share Posted September 26, 2017 Buy the o2 sensor type Denso ? I'm not sure what is the best place to get this in Lebanon. Here you can get it from the regular auto parts store, it might take a few days if they don't have it in stock. May be possible to order online also, but probably better to buy local if you can, just in case of problems you can exchange it. Link to comment Share on other sites More sharing options...
Alsalam4man Posted September 26, 2017 Author Share Posted September 26, 2017 I'm not sure what is the best place to get this in Lebanon. Here you can get it from the regular auto parts store, it might take a few days if they don't have it in stock. May be possible to order online also, but probably better to buy local if you can, just in case of problems you can exchange it.Ok ... I apologize very much for the many questions ... Thank you very much تم الإرسال من SM-A9100 باستخدام Tapatalk Link to comment Share on other sites More sharing options...
MilesA Posted September 26, 2017 Share Posted September 26, 2017 Maafi mushki. Link to comment Share on other sites More sharing options...
