Xplosivo1 Posted December 7, 2013 Share Posted December 7, 2013 For those of you who have the accessport V3, can you list what gauges you are able to live view? There are videos on youtube that show you can set up a gauge view, but I haven't been able to find out what info is available. I have searched for days on the web and have scowered the Cobb website for a list to no avail. Link to comment Share on other sites More sharing options...
Andyjo Posted December 7, 2013 Share Posted December 7, 2013 There's like 8 'pages' of them to select from.... i'd type it out, but you can only get to the gauge selection stuff when it's plugged into the car, not usb (i put in a feature request to let you do setup via usb..) Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 7, 2013 Share Posted December 7, 2013 For those of you who have the accessport V3, can you list what gauges you are able to live view? There are videos on youtube that show you can set up a gauge view, but I haven't been able to find out what info is available. I have searched for days on the web and have scowered the Cobb website for a list to no avail. So...what you're saying is that you searched for days on the "Cobbweb"? Link to comment Share on other sites More sharing options...
Xplosivo1 Posted December 8, 2013 Author Share Posted December 8, 2013 There's like 8 'pages' of them to select from.... i'd type it out, but you can only get to the gauge selection stuff when it's plugged into the car, not usb (i put in a feature request to let you do setup via usb..) Wow I had no idea there were that many options...I thought there were maybe 3 or 4 gauges total. I assume you can see the most common like boost and AFR? Link to comment Share on other sites More sharing options...
Xplosivo1 Posted December 8, 2013 Author Share Posted December 8, 2013 So...what you're saying is that you searched for days on the "Cobbweb"? LMAO! I just spewed liquid through my nose all over my IPad! Glad I have an otter box case. Link to comment Share on other sites More sharing options...
Andyjo Posted December 8, 2013 Share Posted December 8, 2013 Alright, went out and snapped some pics and wrote up the list for yah. I have the -002 model, for my 05 OBXT, not sure if there are more or less in the other models. Enjoy.... A/F Correction 1 A/F Correction 3 A/F Learning 1 A/F Learning 1 A A/F Learning 1 B A/F Learning 1 C A/F Learning 1 D A/F Sens 1 Curr. A/F Sens 1 Ratio AVCS In. Left AVCS In. Right Accel. Position Accel.Volt. Baro. Pressure Battery Volt. Boost Boost Target CL Fuel Target Calculated Load Camshaft Sw Closed Loop Sw Clutch Sw Comm Fuel Final Comm Fuel Map Coolant Temp Crankshaft Sw Dyn. Adv. Mult Dynamic Adv. Exh. Gas Temp Feedback Knock Fine Knock Learn Fuel Economy Fuel Level Fuel Pump Duty Fuel Temp Gear Position Hot-Restart Ent Idle Airflow Idle Mode Sw Idle Spd Target Idle Speed Error Ignition Sw Ignition Timing Inj. Duty Cycle Inj. Latency Inj. PW (No Lat) Inj. PW (w/ Lat) Ink. PW Base Intake Temp Knock Active Sw Knock Sum MAF MAF Volt. Man. Abs. Press. Neutral Pos. Sw. Post-Start HS Post-Start LS Primary Ign. RPM RPM Delta Rad. Fan 1 Sw Rad Fan 2 Sw Req Torque Roughness Cyl 1 Roughness Cyl 2 Roughness Cyl 3 Roughness Cyl 4 TD Boost Error TD Integral TD Proportional TGV Drive Sw. TGV Output Sw. TGV Volt. Left TGV Volt. Right TPS Delta TPS Duty TPS Voltage Target Throttle Throttle Pos. Tip-in Enrich Vehicle Speed Warm-up Enrich Wastegate Dury Wastegate Max Link to comment Share on other sites More sharing options...
Xplosivo1 Posted December 8, 2013 Author Share Posted December 8, 2013 Alright, went out and snapped some pics and wrote up the list for yah. I have the -002 model, for my 05 OBXT, not sure if there are more or less in the other models. Enjoy.... You sir are a gentleman, thank you for doing that! Link to comment Share on other sites More sharing options...
TheMonaLisa Posted January 4, 2014 Share Posted January 4, 2014 What gauges have you chosen to display? I use: A/F sense 1 ratio, boost, knock sum, feedback knock, fine knock learn, DAM. Link to comment Share on other sites More sharing options...
Andyjo Posted January 8, 2014 Share Posted January 8, 2014 I haven't been running w/ it up because I haven't had a chance to rig up a mount for it. But that looks about right for what I'll run when I finally get tuned etc... Link to comment Share on other sites More sharing options...
TheMonaLisa Posted January 25, 2014 Share Posted January 25, 2014 Decided to run these. Found them in an ask Cobb video. After researching the ones I didn't know it makes sense they are the best 5. Thinking coolant temp as my 6th. http://img.tapatalk.com/d/14/01/26/a5u5a8ej.jpg Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
GTRun Posted December 6, 2014 Share Posted December 6, 2014 Thought I'd share this link from Cobb's website, which I found helpful in explaining more details on each of the gauge options and how each is calculated. https://cobb.box.com/subaru-monitor-list Link to comment Share on other sites More sharing options...
