sikend667 Posted May 21, 2013 Share Posted May 21, 2013 ok so im stuck..... got the motor dropped, wiring ran, and now i have no spark.... ignighter tested good coil tested good replaced the crank and cam sensors and still nothing..... any ideas? ecu has power and i have fuel only things not hooked up are the o2 sensor, knock sensor, and i hardwired the fuel pump..... any suggestions would be appriciated. the harness has been completely stripped so no test connecters under dash stuff etc. Link to comment Share on other sites More sharing options...
monkeyposeur Posted May 21, 2013 Share Posted May 21, 2013 Need more information and details about the swap. Which of your cars are you swapping the 22t to? What harness are you running/merged. 22T ecu? Did you swap the + and - wires if running a first gen n/a harness? Does it crank but not start? Have you checked bbs? Link to comment Share on other sites More sharing options...
sikend667 Posted May 21, 2013 Author Share Posted May 21, 2013 swapping into an 87 XT-Turbo harness came with the ecu and motor un molested until i got my hands on it. so its merged to the stock ea82t harness 87.0 MY stock 22T ecu cranks but no spark have fuel pressure Link to comment Share on other sites More sharing options...
monkeyposeur Posted May 21, 2013 Share Posted May 21, 2013 Hmm, probably a problem with the harness. They usually don't just swap over. A first gen legacy n/a harness will swap over if you reverse the polarity of two f the sensors. I bet the XT harness has different pin outs. Btw I love XTs. Link to comment Share on other sites More sharing options...
sikend667 Posted May 21, 2013 Author Share Posted May 21, 2013 i understaand they dont just swap over im looking for what circuits are required in order for the ecu to send a spark signal this is all custom one off stuff i just dont completely understand how the computer works... does it have to sence fuel signal first? is there a bounceback signal? those sorts of things Link to comment Share on other sites More sharing options...
