garvin Posted April 6, 2007 Share Posted April 6, 2007 have a set on and while I am happy with the braking they make alot of noise....? i had the pads scuffed and the rotors scuffed and they still make alot of noise while braking at slow speeds. Right before you stop it makes a hell of alot of noise a LOUD creaking noise. set up ss lines super blue endless ssm's any suggestions? Link to comment Share on other sites More sharing options...
azca Posted April 6, 2007 Share Posted April 6, 2007 could it be shims/back plate or greese? Link to comment Share on other sites More sharing options...
garvin Posted April 6, 2007 Author Share Posted April 6, 2007 had into a brake service place and he said he went thru them and did everything he could think of..... they produce a real harsh sound when you apply the brakes like a grinding sound sand paper on steel sort of thing then right before you stop a loud creaking noise Link to comment Share on other sites More sharing options...
Waxiboy Posted April 6, 2007 Share Posted April 6, 2007 I have the exact brake set up but no noise whatsoever...light nor hard braking. Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted April 6, 2007 Share Posted April 6, 2007 i have ss lines aftermarket fluid and bobcats, i get squeaking all the time when coming to a stop Link to comment Share on other sites More sharing options...
praedet Posted April 6, 2007 Share Posted April 6, 2007 Go out and do a really good bedding on the bads. Do 10 60-10mph stops at almost ABS pressure. (75-80% of full braking) Then park and let them cool down trying not to use the brakes. (You can use the parking brake since it is separate) It sounds like the SS-Ms are grinding instead of mating w/ the rotors... Link to comment Share on other sites More sharing options...
Xenonk Posted April 7, 2007 Share Posted April 7, 2007 my guess is that the retainer clips is what is sliding and making contact onto your rotor.. do you see scarring on the rotor? SSMs are quiet, something is not right. Did you see my How-to install on rotors? I talked about how when installing the rotors, make sure the retainer clips are not rubbing on the rotor when putting new pads back on. There was even a recall or technical service bulletin on a few of the retainer clips usin stock pads that would make the same noise. Keefe Link to comment Share on other sites More sharing options...
Th3Franz Posted April 8, 2007 Share Posted April 8, 2007 yeah the SS-M's are really quiet once you get a little heat in them. They squeal a little bit on the first stop when they are really cold but after that they are very quiet.. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
caramall2 Posted April 9, 2007 Share Posted April 9, 2007 I have the same thing with my Endless. I think it's just that they're a little cold. I love the pads other than that, but when cold, they do creak a bit just before you stop. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted April 29, 2008 Share Posted April 29, 2008 I devolped this slight sand paper on the rotor sound tonight aswell. 05 LGT hawk HPS pads on stock rotors that have been resurfaced 6k miles ago. I did take the pads off to reapply some anti-sieze to them to get them to stop squeeling and I re-bled them also. but when I come to a stop from a low speed right before I stop like 10-15mph and below I get this clunking noise like if you crush sand in a gear or something and I can feel it in the pedal also. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
