SpecBamf41 Posted March 5, 2015 Share Posted March 5, 2015 So prior to me doing it myself, people had said that the kns adapters are not a direct bolt on to our cars and need to be modified to fit the rear brembo calipers. This is wrong buy some modifications are needed that i will show you later on. This may not be applicable to cars with steel knuckles/swing arms in the rear. First, the front brakes are a direct bolt on, that is meaning only the rotors and calipers are needed, and pads of course. And the stock dust sheilds on the front need a slight trim as it looked like the last owner of my car had once had brembos on the car. If you buy brembos with the hubs/ The knuckles, you could bolt the whole assembly, but the abs sensors are different, and you may be downgrading to a "press in" wheel bearing vice a bolt on style that the newer subarus use, your choice. Back to the rears! The only way to mount rear brembo is to buy a adapter bracket (kns, ect) that allows you to bolt the calipers to the new style rear end that came on the 4th gen legacy, the knuckles ARE NOT the same as most older gens and 07 and lower imprezas. You'll also need to decide if you want to buy larger ebrake pads or custom size rotors from kns. I personally just got larger pads because one, i had brembo size rotors with my purchase already, and i needed new pads for the ebrake anyway. So, on to the install. This is on the port, aft, corner of me car if you cant tell Via pics.... All ready did the other side. First jack and stand the wheel or wheels to come off, and take tire off... http://tapatalk.imageshack.com/v2/15/03/05/145bffccd94cc6725253899b8bc30f20.jpg Now unbolt the old caliper, do not unbolt the brake line yet. Fuild will slowly drip from it if its not plugged. I just set it on my lat links.. http://tapatalk.imageshack.com/v2/15/03/05/244992105389b987b30a084fff6092e8.jpg Beat the rotor off if your in mood to beat something, ensure parking brake is not engaged.... Self corrected problem.. http://tapatalk.imageshack.com/v2/15/03/05/44932921c68c4d061cf6fb806dcccc3e.jpg After working up that sweat, take a brake and cooldown. Your about to break out the power tools My local gas station sells 64 oz tap beer, so i picked up a bottle of dogfish head, the 90min type. http://tapatalk.imageshack.com/v2/15/03/05/9d8e3eb67db5dde2b5999f6e6a225dd1.jpg Now this is the problem, http://tapatalk.imageshack.com/v2/15/03/05/44d6a15d384b5bb52210bb8b68e15b0a.jpg Here is where the grinding takes place. Or if your like me, all you had was a jig saw... http://tapatalk.imageshack.com/v2/15/03/05/168144a76b48c91dd55728ff63019831.jpg http://tapatalk.imageshack.com/v2/15/03/05/f2dc55c27e2fbecb0b24cfdeaa6befe9.jpg After you remove that interference, it will bolt right up. After that i basically just changed my ebrake shoes for the larger ones. One last thing you gotta do. Again its your choice. You can bend your dust shield to clear the rotors. Or grind the pinch welds and take it off, again i didnt have a grinder. But i did have a hammer. So i beat with the hammer one last time till it came off. http://tapatalk.imageshack.com/v2/15/03/05/4b76f8c916e1e9808ed8d05be3f36b7e.jpg Didnt have much pictures after that, i forgot the growler was 9 %, but thats the biggest inconvenience with the install, plus the brake line will not line up perfectly between the little posts, just bolt it on with the line going the way it wants to naturally . Would be easier to explain with pictures.. BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted March 5, 2015 Author Share Posted March 5, 2015 Finished pictures, http://tapatalk.imageshack.com/v2/15/03/06/87ef6410ae44f90b32bf6f478a494b50.jpg http://tapatalk.imageshack.com/v2/15/03/06/c2391e14ee96e63befe186d1a3a603f6.jpg BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted March 6, 2015 Author Share Posted March 6, 2015 Anyone else confirm that the steel swing arm legacy does not have this problem? BNR18g on 93oct Link to comment Share on other sites More sharing options...
Redslaya Posted March 6, 2015 Share Posted March 6, 2015 no finished pics? thanks for a good write up with plenty of great pictures! Link to comment Share on other sites More sharing options...
JayInVA Posted March 6, 2015 Share Posted March 6, 2015 What year STI did you get the Brembos from? And is there a "going rate" for buying a used set of Brembo calipers? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted March 6, 2015 Author Share Posted March 6, 2015 Finished pics added BNR18g on 93oct Link to comment Share on other sites More sharing options...
starionesir Posted March 6, 2015 Share Posted March 6, 2015 The steel arms have to be ground as well. The upper bolt will not clear other wise. Nothing a grinder and flap disc can't take care of though. If it was me I'd use a grinder and smooth out all those jagged cuts. A flap disc will make short work of the aluminum. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted March 6, 2015 Share Posted March 6, 2015 Both need to be ground down, but the aluminum SpecB arms need a little more. Link to comment Share on other sites More sharing options...
sbw Posted March 6, 2015 Share Posted March 6, 2015 I approve of brembos and dogfish 90 minute. Mine had to be grinded as well for those brackets... Link to comment Share on other sites More sharing options...
scoobyscoodle Posted March 6, 2015 Share Posted March 6, 2015 I wish my local gas station sold dogfish 90 minute in growlers!! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted March 6, 2015 Author Share Posted March 6, 2015 Yea. Im still working on it. Pretty strong shitm BNR18g on 93oct Link to comment Share on other sites More sharing options...
sbw Posted March 7, 2015 Share Posted March 7, 2015 Im not a huge fan of the 120 min. Maybe it needs to really be aged more, but personally if I want some high octane IPA I'll go for the six point Resin or even the High-Res. Link to comment Share on other sites More sharing options...
SpecBFan Posted March 7, 2015 Share Posted March 7, 2015 Great job and nice write up!! I was able to get the rear brackets on without any grinding. I bought the setup used so maybe the previous owner modified the bracket. Here's a few pictures of mine. http://tapatalk.imageshack.com/v2/15/03/06/ee09980a2998155fba4c5fc712e2b675.jpghttp://tapatalk.imageshack.com/v2/15/03/06/ffde5582594bdec2de92ede04dfe9b92.jpg P.S. I like the gold setup. Sent from a controlling box in my pocket Link to comment Share on other sites More sharing options...
ragman Posted March 7, 2015 Share Posted March 7, 2015 What year STI did you get the Brembos from? And is there a "going rate" for buying a used set of Brembo calipers? It's like 04-08 STI brembos, I think. Decent ones go for ~$800 for just calipers. Plus everything else. Link to comment Share on other sites More sharing options...
WRX USA Posted March 7, 2015 Share Posted March 7, 2015 It's like 04-08 STI brembos, I think. Decent ones go for ~$800 for just calipers. Plus everything else. For the rears its 04-07 USDM STi or JDM STi Bugeye. http://i672.photobucket.com/albums/vv87/JoshEAllen/49447B13-FC6E-466B-9413-4FDBC84D8C83.jpg Mine on my 09 OBXT with SpecB trailing arms and KNS brackets and KNS shortened brake line (for Brembo conversions, http://www.knsbrakes.com/c/caliper-item/2286_Subaru+V1+Rear+STI+Brembo+Caliper+Upgrade+w%2F+DBA+Adapter+Rotor/53553_Rear+Stainless+Steel+Brake+Lines+-+For+Legacy) Link to comment Share on other sites More sharing options...
Wang Lung Posted March 7, 2015 Share Posted March 7, 2015 SpecBamf41, what is the pink stuff in the bottle next to the beer. Link to comment Share on other sites More sharing options...
SpecBFan Posted March 7, 2015 Share Posted March 7, 2015 It looks like liquid for his vapor set up. Sent from a controlling box in my pocket Link to comment Share on other sites More sharing options...
SpecBamf41 Posted March 11, 2015 Author Share Posted March 11, 2015 it is the vape juice indeed.. question, can i buy the sti brake cylinder and mount it to my brake booster? or do i need the whole assemble BNR18g on 93oct Link to comment Share on other sites More sharing options...
Gex Posted March 11, 2015 Share Posted March 11, 2015 Need the whole assembly. They are under $100 on eBay. Just make sure you do a good bench bleed. Link to comment Share on other sites More sharing options...
Nubie Posted May 6, 2015 Share Posted May 6, 2015 So I had a couple problems this weekend with my Brembo install, specifically the rear KNS parts. Ive already contacted Ken at KNS and let him know and he acknowledged the issue. He said I was the second one with this problem. He is already working on correcting the issue. Im posting incase someone else runs into it before the problem is taken care of. My Ebrake adapter shoes had their "hold down pin" hole about a 1/4-1/2" off. Im talking about the thin spear like pin that runs thru a wide spring. The extra distance caused the shoe to sit too high. My car was already apart and it was friday night, knowing any replacements were gonna take a few days, I made the executive decision to re drill it in the correct spot. If you look at the picture the smaller of the two holes is the one I drilled. If you encounter this problem just drill it. This pin simply holds the shoe against the backing plate, it is not a pivot so it doesnt have to be perfect, just somewhat lined up. I matched up the old and new shoes and put a center punch through the old pad to mark the new one. I had to do this on all 4 shoes. http://imgur.com/uJNQPB5.jpg Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 6, 2015 Author Share Posted May 6, 2015 I did not have this problem. I did how ever have to exchange something from one to the other as it appeared in had a set if pads for one side of the car only. BNR18g on 93oct Link to comment Share on other sites More sharing options...
angeltalin Posted May 6, 2015 Share Posted May 6, 2015 I think I had the same issue as ^^^^ had to pull pins from my old shoes and put in the new ones cuz they came without pins StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
