RMiles87 Posted February 27, 2010 Share Posted February 27, 2010 So I got a set of stock wrx struts and while i wad torqueing them down I snapped one of the dang bolts off the drivers side frot strut. :-/ my question is, can I just punch the broken stud out and replace it with one from my legacy tophat? On a side note, the car is sitting so low. I just need to figure this out, bleed the brakes better(it was one scary test drive), and get the rear ones put in and i should be golden. Had to drive my girlfriends Pontiac to work tonigh. Link to comment Share on other sites More sharing options...
Vascoobiedude Posted February 27, 2010 Share Posted February 27, 2010 yup. should work. Link to comment Share on other sites More sharing options...
RMiles87 Posted February 27, 2010 Author Share Posted February 27, 2010 So any advice on bleeding the brakes the right way? I don't think i did it right. Link to comment Share on other sites More sharing options...
Vascoobiedude Posted February 27, 2010 Share Posted February 27, 2010 Start withe the caliper farthest from the master cylinder, bleed that. Work from there to the closest one. Have you bled brakes before? Should be good if you go that way. What year is it? Link to comment Share on other sites More sharing options...
RMiles87 Posted February 27, 2010 Author Share Posted February 27, 2010 It's a 98 gt. So I just pull the bleeder valves do it that way starting in the back? I havnt done it before. I tried earlier but it didn't work out. Link to comment Share on other sites More sharing options...
gathermewool Posted February 27, 2010 Share Posted February 27, 2010 What do you mean you "pull the bleeder valves"? I found these instructions a while back, but don't remember who from, so I can't quote him/her: Bleeding The Brakes This page arose out of replying to topics on UBB's all the time on how to bleed brakes. It's not a difficult process, but it is best done with two people. You can use these instructions to completely flush the brake system or just to bleed them after a brake job. If you do a complete flush, have 32 to 64 fluid ounces of your favorite handy to refill the system. If you are only bleeding the air out of the system, 16 ounces should do. STEP ONE The first thing to do is get yourself the needed materials: brake fluid, a small bottle, some clear plastic tubing, and some food to bribe one of your buddies to help you out. Next, get the car on jackstands, with the wheels off. This seems like overkill, but it will make the job alot easier. That being said, you can do this one wheel at a time on the stock jack if you lack jackstands or a floor jack if you so desire. Having the wheels off is a good idea because it allows you to see what you are doing much better, and it gives you a chance to inspect the rotors and brake pads in detail while you are at it. With the wheels off and the car up, it's time to open the hood and go at it. STEP TWO Uncap the brake fluid reservoir to allow you to fill the reservoir as the fluid level goes down and also to allow any trapped air to bubble out at this end of the braking system. STEP THREE Subaru uses a diagonal systm and the bleed order isn't the standard "Start from the furthest point" Deal. Go to the passenger side front corner of the car. On the top of the brake caliper, you will see a small black dust cap over a nipple with a nut at the base- this is the bleeder valve. You want to start here, as this is the farthest point away from the Master Cylinder. Pull the rubber dust cap off the bleeder valve, and attach a 4 or 5 inch length of 1/4" clear plastic tubing to the nipple. The clear tubing will allow you to see any air bubbles that rise out of the caliper as you bleed the brake system. Place the other end of the tubing into the bottle or cup you have handy to catch the expelled brake fluid. Whatever fluid you bleed out of the system DO NOT SAVE- it will be contaminated with anything from dirt to water, and you do not want to put this back into the system. Dispose of it in the same way you would used motor oil. STEP FOUR Now is the point where you need that good buddy. Have your helper gently pump the brakes. Push the pedal to the floor and hold down the pedal. Now you open the bleeder valve (righty tighty, lefty loosy applies here) to let out the brake fluid. When it stops coming out close the bleeder valve and have your partner gently pump the brakes back up then hold the pedal to the floor again. In any event, you want your friend to continue this process until no more air bubbles, not even very tiny ones, are visible in the clear tubing. It is better to waste 4 ounces of fluid than to leave a bubble in the lines. Check frequently to make sure there is PLENTY of fluid in the reservoir if you are bleeding the system- if it runs too low, you will suck air in at the Master Cylinder, and you will need to start all over again. Keeping the Master Cylinder topped off in the bleeding process is CRITICAL. STEP FIVE Once you get no more bubbles in the line, have your friend push the brake pedal to the floor AND HOLD IT THERE. What you need to do is to tighten the bleeder valve back down tight while he or she has the pedal held to the floor. Make certain they do not release the brake pedal until you have the bleeder valve tight again. STEP SIX Repeat steps three through five on the other corners of the car, in this order: (see pic at bottom part of page) · Driver's Side Rear · Driver's Side Front · Passenger's Side rear Doing so will ensure that you are pushing almost all the air out of the system, making each subsequent corner easier to bleed. If you are completely draining and flushing the system, doing so in the same order will ensure almost all of the fluid is out of the system at the first corner, again making each subsequent corner easier to do. STEP SEVEN The final step is to top off the Master Cylinder to the top "fill" line and cap off the reservoir. If you completely flush the system and refill it, it is probably best to rebleed the brakes after a week to ensure you have no trapped air in the system- completely draining the lines introduces a good deal of air into the system, and it is best to make certain it is all removed. '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
