bradlgt21 Posted April 30, 2009 Share Posted April 30, 2009 So I am planning on installing my Cobb STS this weekend and read all the walkthroughs. I just have 1 question before I start. The metal trim that surrounds the shifter. I read a walkthrough of a kartboy shifter where the guy removed the trim and turned it around so the front was in the back bolted it up and it worked. The cobb walk through suggests trimming the top of the trim to be able to go into 1st. Can I flip the trim around with the cobb shifter like the guy did with the kartboy or is cobb to low to do that and it will cause problems in 2nd, 3rd, and reverse? I bought my Cobb used so no instructions came with it. I think I can figure it out but I don't have instructions on how to adjust the height. The top rod is for heigh and the bottom is for throw? Link to comment Share on other sites More sharing options...
PhillyWilly Posted April 30, 2009 Share Posted April 30, 2009 pretty sure you could flip it. i didnt touch mine. i adjusted the bottom of the cobb sts leaving about 1/8" clearance. works fine. Link to comment Share on other sites More sharing options...
bradlgt21 Posted April 30, 2009 Author Share Posted April 30, 2009 Yeah I don't need my shifter slammed. So I will monkey with it when I get it in the car. Worse case scenerio I have to flip it and it still touches so I use a dremel, but I would prefer to avoid cutting if I can. Link to comment Share on other sites More sharing options...
Underdog Posted April 30, 2009 Share Posted April 30, 2009 You can't flip it as far as I know. There is a vertical bracket that attaches the center arm-rest to the car that will be in the wrong spot if flipped. You can dremel out a little clearance with no problem. Alternatively, you can set the shifter to be just shy of contact, however it may touch due to the movement of the engine/transmission. I took a dremel and removed about 1/8" in the corner and have had no issues since. The Crimson Dynamo Link to comment Share on other sites More sharing options...
bradlgt21 Posted April 30, 2009 Author Share Posted April 30, 2009 Hmm that's weird because some guy did it in his walkthrough like that. Link to comment Share on other sites More sharing options...
Underdog Posted April 30, 2009 Share Posted April 30, 2009 Yeah, I had read that prior to my installation a year+ ago... During my first install I decided to set it just shy of contact and see how I liked it. After a few months I decided to adjust it lower and went into it with flipping the plate in mind. It wasn't until I started undoing everything that I realized the plate could not be flipped around, nor would it be worth the hassle of seperating the upright bracket from the plate in question. A dremel grinding wheel + a beer + 5 minutes, and it was all said and done. I have only had to go back in once to re-lube everything with mobil1 chassis grease. I may go back in now (a year later) just to inspect and re-lube. The Crimson Dynamo Link to comment Share on other sites More sharing options...
rony Posted May 1, 2009 Share Posted May 1, 2009 I just trimmed mine with a cutoff tool and file. My Car vBGarage Link to comment Share on other sites More sharing options...
JohnnyT Posted October 6, 2010 Share Posted October 6, 2010 I cut the whole corner out. With a dremel it was easy. Link to comment Share on other sites More sharing options...
