gardorr Posted January 3, 2013 Share Posted January 3, 2013 So I recently installed a new motor in my legacy. Before the swap, the car ran great. After the swap, the car is having issues accelerating under load. It idles fine and when its out of gear it revs up smooth, but as soon as I take it for a drive, it bogs down, accelerates slowly, and gets kind of jerky until I reach about 3,300 RPM's than surges and runs smooth. I've tried installing a new MAF sensor and ECM, but the issue persisted. The one thing I did notice is when I disconnect the ECM for a short period of time and plug it back in, the car drives great for approximately 10-20 minutes than gets progressively worse until the issue completely returns. Also its seems that when I unplug/plug the ECM while the car is cold it runs great for a longer period of time, as opposed to unplugging/plugging the ECM while the car is warm. I'm at a loss, so any idea's would be a tremendous help. Link to comment Share on other sites More sharing options...
Tr00b Posted January 4, 2013 Share Posted January 4, 2013 Welcome to the forum. Sounds like you have a sensor problem. Since you don't have a Check engine light, its hard to say where to start. How clean are your grounds in the engine bay? Did you hook them all back up after the swap? Double checked that all of the sensors are connected and the harnesses are undamaged? Did you use the old harness in your car or did you swap harnesses? What motor from what year car did you swap in, and what year is your car and what motor did it have before?Did you verify the timing of the engine before you installed it? Link to comment Share on other sites More sharing options...
pqkillerAU Posted January 4, 2013 Share Posted January 4, 2013 Exhaust sensor, poor fuel, spark plugs. Link to comment Share on other sites More sharing options...
spooln30 Posted January 5, 2013 Share Posted January 5, 2013 Auto or 5spd? If it's an auto it sounds like your starting out in 3rd gear. Link to comment Share on other sites More sharing options...
gardorr Posted January 6, 2013 Author Share Posted January 6, 2013 Thanks for the reply's, So, all the grounds are connected and I made sure they were clean. Double and triple checked all my connections. The motor was completely rebuilt, timing is correct and I'm using my original wiring harness that had no issues prior to the install. Also I have a 5spd, and I replaced the clutch at the same time as the motor install. I figured it must be a sensor issue. I tried disconnecting my o2 sensor to keep the car in open loop, but the car ran exactly the same. Does anyone know which sensors wouldn't throw a code? Link to comment Share on other sites More sharing options...
Metalstorm Posted January 7, 2013 Share Posted January 7, 2013 Another possibility is a clogged cat. Once they start disintegrating, the car will run crappy and get worse & worse over time as the pieces begin to block more & more exhaust passage. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 7, 2013 Share Posted January 7, 2013 sounds like you have a cel that clears and pops back up after some cylcles and puts car in some kinda limp mode. does your cel light work? BNR18g on 93oct Link to comment Share on other sites More sharing options...
gardorr Posted January 7, 2013 Author Share Posted January 7, 2013 Yeah my cel works, and I've hooked it up to a scan tool, and didn't find any codes. It feels like it's in limp mode, that's why I started to think it might be the o2 sensor, but the car ran the same with the front o2 disconnected. Link to comment Share on other sites More sharing options...
