Iltl32 Posted September 11, 2014 Share Posted September 11, 2014 2007 Legacy Limited. 89K miles. I'm leaking oil somewhere from the top of the engine; you can see it pooling up on the engine case and I'm losing it fast enough that I'd run low before my next oil change if I let it go. One mechanic said he thinks it's the head gaskets, but I don't seem to be losing any coolant at all. So, two questions: 1. Is it possible for the head gaskets to leak without losing coolant? 2. If it's not them, any ideas where the leak is coming from? Is there a common place where this happens? Link to comment Share on other sites More sharing options...
compsurge Posted September 11, 2014 Share Posted September 11, 2014 1. Yes. 2. Turbo? Take a picture (or find one on the internet) and identify where the oil is pooling. We can't really help otherwise. Link to comment Share on other sites More sharing options...
c-lo Posted September 11, 2014 Share Posted September 11, 2014 based on my own personal experience.......yes. I'm at 265k on my 05 and mine are leaking in the same spot. I went 4k miles between last oil change and over the course of a couple weeks before i changed the oil I had to add a total of 1 quart. and I'm not losing coolant, nor blowing smoke. I do leave oil spots on the ground, but not all the time. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Iltl32 Posted September 12, 2014 Author Share Posted September 12, 2014 No turbo on here. Here's a picture, circled in red is where the oil is pooled. I've never seen a spot on the ground but I'm definitely losing it pretty quickly at this point. http://i.imgur.com/Mc5lw4D.jpg thanks for your time. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted September 12, 2014 Share Posted September 12, 2014 are you sure its not power steering fluid? Link to comment Share on other sites More sharing options...
c-lo Posted September 12, 2014 Share Posted September 12, 2014 are you sure its not power steering fluid? right. I'm thinking power steering. dab it with a white paper towel. Pink = power steering. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
compsurge Posted September 12, 2014 Share Posted September 12, 2014 If it's really pooling up, you should be able to notice the reservoir for the PS is low. By "losing it quickly", are you measuring your oil level? Is oil disappearing every week and the dipstick reading lower? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 12, 2014 Share Posted September 12, 2014 Glad to see I'm not the only one with those thought's. Unless 2.5i's have a oil galley fitting there...? But they are all the same basic block. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted September 13, 2014 Share Posted September 13, 2014 Did you eyeball the pressure sender unit? It's offset to that side of the motor, kind of..... Link to comment Share on other sites More sharing options...
Iltl32 Posted September 13, 2014 Author Share Posted September 13, 2014 It's definitely oil, I've cleaned it up with paper towels before. I'm losing about a quarter inch of oil from the dipstick every hundred miles. I'll check the pressure sender unit, once I figure out what that is. Link to comment Share on other sites More sharing options...
compsurge Posted September 13, 2014 Share Posted September 13, 2014 Well, is there any reason to not believe your mechanic? Link to comment Share on other sites More sharing options...
nm Posted September 13, 2014 Share Posted September 13, 2014 FYI, not all head gaskets leaks leak coolant. Link to comment Share on other sites More sharing options...
apexi Posted September 13, 2014 Share Posted September 13, 2014 I think this picture attached from my car is the oil pressure sensor. I would imagine that even though the picture in the link below is from the outback forums, it should still accurately describe our 2.5i engines. If so, there does appear to be an oil passage up near where you are seeing oil puddle. http://www.subaruoutback.org/forums/attachments/problems-maintenance/26890d1358252067-oil-filter-head-gasket-head.jpg Link to comment Share on other sites More sharing options...
Iltl32 Posted September 13, 2014 Author Share Posted September 13, 2014 Well, is there any reason to not believe your mechanic? It doesn't seem to make sense for a head leak to pool there and I don't want to spend over a thousand dollars on something I don't need is all. Also this was a dealer who told me that and they've lied to me before at this shop. Link to comment Share on other sites More sharing options...
Iltl32 Posted September 13, 2014 Author Share Posted September 13, 2014 So it could just be the oil pressure sensor? Link to comment Share on other sites More sharing options...
compsurge Posted September 13, 2014 Share Posted September 13, 2014 Oil pressure sensors fail and are cheap. Look on Rock Auto for a replacement. I fixed one on a VW that was leaking and actually made it look like the pan gasket had failed. $10 fix for my friend. Link to comment Share on other sites More sharing options...
